It is currently Thu Nov 19, 2026 5:14 am
 Post subject: GIMP 2.10.34 snow.gdyn file
PostPosted: Wed Mar 29, 2023 5:37 am  (#1)
I just installed gimp 2.10.34, and everything seems ok.
but when I look in my DINAMICS it is missing dinamic snow,i check my dynamics folder and the dynamic snow is in it
but when i open gimp and i go to my dinamics it doesn't show there.
i go back to my dinamics folder, delete the snow.gdyn file ,then i install it again.
i close gimp and open it again but no result the dinamics snow is not visible.
does anyone know what i could do to fix it.
thanks in advance,gimper
 Post subject: Re: GIMP 2.10.34 snow.gdyn file
PostPosted: Wed Mar 29, 2023 12:50 pm  (#2)
You show that Snow.gdyn is installed in Downloads>dinamics
This is not the usual place to install dynamics. The usual place is
C:\Users\(your name)\AppData\Roaming\GIMP\2.10\dynamics
Does it work if you put it there?
Or you can add a line to Edit>Preferences>Folders>Dynamics to point to Downloads>dinamics
PostPosted: Thu Mar 30, 2023 2:32 am  (#3)
Blighty, thanks for your response
I always do it the right way as you can see below.
In the meantime I found the reason, the problem was in the preferences dynamics folder.
problem solved,gimper
