It is currently Thu Nov 19, 2026 10:34 pm
 Post subject: Burnt Wood Text Effect
PostPosted: Wed Jun 22, 2011 10:50 pm  (#1)
I dont know what it is but i do a ton of text effects! I guess i just like them haha. Anyways heres another one which i can probably make a short tutorial on! Burnt Wood Text! (And i didn't use the Burn layer mode at all)
 Post subject: Re: Burnt Wood Text Effect
PostPosted: Wed Aug 31, 2011 12:39 pm  (#2)
I like to fool around with different text effects too and you gave me another idea for getting that "burn't" look. I didn't get the relief effect just right but what the heck. This would make a nice script if someone is up to the challenge.
PostPosted: Wed Aug 31, 2011 1:19 pm  (#3)
Looks nice Draconian. Did you make that smoke, or is it part of the font? Maybe a shadow or a bevel might make it look more 3D, like it is burned into the wood.
PostPosted: Wed Aug 31, 2011 2:15 pm  (#4)
:tyspin
I would really like to see more activity on this topic.
PostPosted: Wed Aug 31, 2011 5:42 pm  (#5)
Molly,
I did put a shadow on the left side and a highlight on the right. Maybe I need to change the opacity of the text layer to be a little lighter so you can see the shadow more clearly. Like I said I didn't get the relief just right.
The smoke is a set of brushes I downloaded somewhere. Here's the zip file.
gimp_smoke_brushes.zip [372.9 KiB]
Downloaded 271 times
PostPosted: Wed Aug 31, 2011 5:47 pm  (#6)
You shoud be able to see the shadow better now.
PostPosted: Wed Aug 31, 2011 6:33 pm  (#7)
When you do your shadow, do you use light and shadow, then drop shadow? I can't see your shadow.
PostPosted: Thu Sep 01, 2011 4:17 am  (#8)
The shadow is inside the text on the top-left and the hi-lite is on the bottom-right (inside the text). :)
Both are nicely done.
PostPosted: Thu Sep 01, 2011 5:03 am  (#9)
What I was trying to say is that I would like to see a bit of the wood behind the text look like it is burned into it.
Yes, it is very nicely done. I love the way you put the smoke around the cracks to make it look like it is still smoldering.
PostPosted: Thu Sep 01, 2011 10:17 am  (#10)
Adding singing to the wood (black in overlay mode) also helps add realism (it would be better under the smoke, of course ;) ):
-Rob A>
PostPosted: Thu Sep 01, 2011 10:44 am  (#11)
That is what i was going to suggest, a burnt outline around the text itself.
Nice Rob! :)
PostPosted: Thu Sep 01, 2011 11:39 am  (#12)
Is this mo bedder gooder?
See what you started jfish!
burned.rar [923.75 KiB]
Downloaded 771 times
PostPosted: Fri Sep 14, 2012 7:29 pm  (#13)
-Rob A>
That's the effect I was looking for RobA, very real
PostPosted: Sat Sep 15, 2012 8:01 am  (#14)
I just had to have a go at this. I found it very difficult to come up with a convincing representation of a burnt image such as would be made with a branding iron (letters or logo).
The burnt imprint should appear beneath the surface. So it must have slight indents "walls" inside the print but there should not be a very big difference in colour as the walls are burnt almost black or very deep brown, as is the bottom . The differences in colour should be minimal yet convey a feeling of depth. At the top there will be minimal lateral burns in the grain of the wood. There will also be a slight discolouration around the shape as the heat burns sideways as well as downwards. And generally there will a larger area that will be discoloured from smoke and heat.
I tried to keep these criteria in mind but I am not that happy that I achieved what I wanted. Anyway here is my interpretation of a burned imprint.
PostPosted: Sat Sep 15, 2012 8:04 am  (#15)
That's a pretty convincing wood burn Wbool.
PostPosted: Sat Sep 15, 2012 8:10 am  (#16)
Thank You Erisian
PostPosted: Sat Sep 15, 2012 8:35 am  (#17)
That does look pretty darn good wbool63. I tend to agree with your thought process and Rob As' interpretation is valid as well. One point to consider is the implement doing the branding will make a big difference in hte appearance of hte end result. Whether it is a solid or 'filled' letter or just the outline. The outline would render more of the effect like you got whereas mine and Rob As' looks more like flat metal letters were used to do the branding. Just a thought.
I still think this would be a great script either stand alone or as an option in another script like 'logo workshop' perhaps. I have no idea how the script would have to be written to add the random smoke though.
PostPosted: Sat Sep 15, 2012 8:50 am  (#18)
Very nice wooble, you always put a lot of thought in your creations
PostPosted: Sun Sep 23, 2012 10:02 pm  (#19)
I gave it a go myself. :)
PostPosted: Mon Sep 24, 2012 8:18 am  (#20)
I thought maybe a bit of a bevel would do it but with both of these I used the tutorial in this thread and thought they didnt really look authentic
