It is currently Thu Nov 19, 2026 4:19 am
 Post subject: WRITING A TEXT IN THE FRONT AROUND AN OBJECT
PostPosted: Thu Aug 10, 2023 4:39 am  (#1)
as shown in the picture here is a text written in front of an object and the text is in line with the object.
is there a tutorial somewhere in gimp or someone who knows how to make such text editing.
​a selection should be made, and within that selection write the text. the text should automatically adjust to the curves of the selection.
maybe something possible with a path ??ii
maybe there is a genius somewhere among the gimpers or among our scriptwriters.
in anticipation of a successful outcome to my question, thanks in advance
gimper66
 Post subject: Re: WRITING A TEXT IN THE FRONT AROUND AN OBJECT
PostPosted: Thu Aug 10, 2023 5:12 am  (#2)
Not in Gimp. Typically something for a typesetting application (Scribus or else).
PostPosted: Thu Aug 10, 2023 6:02 am  (#3)
there is a possibility in photoshop, it is not a typesetting there either, but a modified version to imitate it.
File comment: in the folder a photoshop tutorial
1.zip [1.05 MiB]
Downloaded 60 times
PostPosted: Thu Aug 10, 2023 7:00 am  (#4)
There is also Inkscape. Flow text into frame. Then into Gimp to add background...etc...
PostPosted: Thu Aug 10, 2023 8:42 am  (#5)
Tim created a plugin called "Filled Text Selection Plug-in" and I think if you invert the selection it might do it.
Since he erased everything in his website, you can't download anything even at "Wayback Machine". :hoh Maybe someone here have the plugin and might be able to share it.
PostPosted: Thu Aug 10, 2023 8:59 am  (#6)
Rich2005's solution to the problem via Inkscape is what I do.
PostPosted: Thu Aug 10, 2023 9:59 am  (#7)
Thanks Pocholo for the keywords.
@gimper66, Here you go ;)
Filled Text Selection Plug-in to download (version/revision 11), in the menu it's in > Python-Fu/Filled Text Selection... :yes
filled_text_selection.py.7z [2.82 KiB]
Downloaded 64 times
I did found the topic as well, it's here on GC > viewtopic.php?f=9&t=17273 (on the second page it gives nice results)
EDIT: do NOT download this one, it misses 1 script, see my next post.
Patrice
PostPosted: Fri Aug 11, 2023 3:12 am  (#8)
Ok, you do need 2 scripts.
1st to prepare the text with format that the 2nd script can handle to Fill the selection, or the text will be too stretched and ugly
I did put the 2 scripts together (delete the old one in your plugins folder or it will interfere), both paths in the menu are in Filters/Text/Text fit selection/ (Prepare then Fill)
Yeah I took it directly from my plugins directory, thus it's my menu path
fill text to selection.7z [4.35 KiB]
Downloaded 74 times
How to use it?
Paste your text with the text tool (I did it with the option Box > Fixed)
Then make a selection, work on your selection, in my example a rectangle then an ellipse in minus mode
Then select your text in the layers' dialog and go to Filters > Text > Text fit Selection > Prepare Text Into Selection...
Let the script doing its job for a while (watch the bar at the bottom of GIMP),
once it's finished, you get a new text layer with the text aligned on the left and no more selection.
Untick the visibility of the original text below in the layers' stack, then go to the channel dialog and click that button to "re"-select
Go back to the layers' dialog select the new text generated by the "Prepare" script
then launch the second script Filters > Text / Text fit selection/ Fill selection with text..
Result (it's quite nice :clap )
Patrice
PostPosted: Fri Aug 11, 2023 6:56 am  (#9)
pixlap,
thank you thank you thank you
I did a first text edit here around the seagull and fantastic it works perfectly.
now I have to refine my texts myself and or adjust my selection frame, I will work with that so that I get nice results.
thanks again for the quick response and the great result.
gimper66
PostPosted: Fri Aug 11, 2023 11:25 am  (#10)
I have made the edit again, but see that the text lines are not all of the same size.
is it possible that i'm doing something wrong or is it normal that the text lines don't have the same size?
gimper66
PostPosted: Fri Aug 11, 2023 9:40 pm  (#11)
gimper66
May we see the text you pasted before any "transform/prepare"? Or even better if you can sent a zip of your final xcf, I would like to see and try to reproduce the imperfection to understand why it is happening.
Patrice
PostPosted: Sat Aug 12, 2023 4:27 am  (#12)
PixLab,Good morning
as you can see my text size is the same all over the line
but during processing different sizes show up
As requested I have attached the xcf, thanks again for your efforts.
gimper66
TEKST IN SELECTIE.zip [4.09 MiB]
Downloaded 59 times
PostPosted: Sat Aug 12, 2023 5:28 am  (#13)
Sometimes a problem, Tin's plugins squashes / grows the text.
This is using Inkscape and the gimp-to-inkscape plugin https://www.gimpscripts.net/2023/07/gim ... scape.html Word spacing can be a problem here as well but it is possible to adjust in real time using Inkscape.
4 minutes duration https://youtu.be/p7Hd25vmKJ0
PostPosted: Sat Aug 12, 2023 6:47 am  (#14)
I cannot try with the very text in your XCF as I did not have that font nor the language installed on my system , when I clicked to edit it to change the size I got just hieroglyph ala Greek alike.
Thus I tried with some space-ipsum, and indeed depending the size of the words, and like rich2005, I got some lines bigger than others
Example:
Depending your needs, this script can be an option ;) it might work better when there are paragraphs, though.
I think the rich2005 method is better, a slightly bit more manipulation, but with the script GIMP to Inkscape, it should be very smooth ;)
Patrice
PostPosted: Sat Aug 12, 2023 8:10 am  (#15)
Rich2005
thanks for posting this tutorial.
Am very happy with that!
