It is currently Fri Nov 20, 2026 10:21 pm
Post new topic Reply to topic  [ 94 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Outcomes of a new toy: ABSTRACT PLUS...
PostPosted: Mon Oct 16, 2023 1:24 am  (#1)
If someone will be so kind to comment, please consider that:
- it was born really as a toy
- it likes to create outcomes with abstract looks
Experiments completed, removed the WIP attribute
Just to start.
2023-10-16 08-10-24 thanti-riess-U_b-eSviHvs-unsplash with a Quick Effect G (Twirl) (abstr.mode=LAYER_MODE_HARDLIGHT (75%).jpeg
2023-10-16 08-10-24 thanti-riess-U_b-eSviHvs-unsplash with a Quick Effect G (Twirl) (abstr.mode=LAYER_MODE_HARDLIGHT (75%).jpeg [ 1.47 MiB | Viewed 61206 times ]
 Post subject: Re: Outcomes of a WIP toy: ABSTRACT PLUS...
PostPosted: Mon Oct 16, 2023 1:27 am  (#2)
Other effects.
2023-10-16 08-13-57 thanti-riess-U_b-eSviHvs-unsplash with a Quick Effect I (Triangular Pattern) (abstr.mode=LAYER_MODE_HARDLIGHT.jpeg
2023-10-16 08-13-57 thanti-riess-U_b-eSviHvs-unsplash with a Quick Effect I (Triangular Pattern) (abstr.mode=LAYER_MODE_HARDLIGHT.jpeg [ 854.53 KiB | Viewed 61205 times ]
2023-10-16 08-14-56 thanti-riess-U_b-eSviHvs-unsplash with a Quick Effect H (Textured Glass) (abstr.mode=LAYER_MODE_HARDLIGHT (100%).jpeg
2023-10-16 08-14-56 thanti-riess-U_b-eSviHvs-unsplash with a Quick Effect H (Textured Glass) (abstr.mode=LAYER_MODE_HARDLIGHT (100%).jpeg [ 1.31 MiB | Viewed 61205 times ]
2023-10-16 08-16-38 thanti-riess-U_b-eSviHvs-unsplash with a Quick Effect J (Circle Art) (abstr.mode=LAYER_MODE_HARDLIGHT.jpeg
2023-10-16 08-16-38 thanti-riess-U_b-eSviHvs-unsplash with a Quick Effect J (Circle Art) (abstr.mode=LAYER_MODE_HARDLIGHT.jpeg [ 522.71 KiB | Viewed 61205 times ]
PostPosted: Mon Oct 16, 2023 1:28 am  (#3)
...and
2023-10-16 08-18-43 thanti-riess-U_b-eSviHvs-unsplash with a Quick Effect M (Corner Gradient) (abstr.mode=LAYER_MODE_HARDLIGHT (LINEAR-LIGHT).jpeg
2023-10-16 08-18-43 thanti-riess-U_b-eSviHvs-unsplash with a Quick Effect M (Corner Gradient) (abstr.mode=LAYER_MODE_HARDLIGHT (LINEAR-LIGHT).jpeg [ 688.24 KiB | Viewed 61205 times ]
2023-10-16 08-20-23 thanti-riess-U_b-eSviHvs-unsplash with a Quick Effect N (Random Gradient) (abstr.mode=LAYER_MODE_HARDLIGHT (DISSOLVE 20%).jpeg
2023-10-16 08-20-23 thanti-riess-U_b-eSviHvs-unsplash with a Quick Effect N (Random Gradient) (abstr.mode=LAYER_MODE_HARDLIGHT (DISSOLVE 20%).jpeg [ 1.93 MiB | Viewed 61205 times ]
PostPosted: Mon Oct 16, 2023 1:57 am  (#4)
Beautiful Outcomes, Dinasset. :clap :yes
2023-10-14 07-47-06 croatia-238324_1920 with a Quick Effect L (Memoakten Algorithm A).JPG
2023-10-14 07-47-06 croatia-238324_1920 with a Quick Effect L (Memoakten Algorithm A).JPG [ 845.94 KiB | Viewed 61200 times ]
2023-10-14 12-18-26 valencia-4791102_SOURCE with a Quick Effect W (SpiralRGB).JPG
2023-10-14 12-18-26 valencia-4791102_SOURCE with a Quick Effect W (SpiralRGB).JPG [ 1 MiB | Viewed 61200 times ]
2023-10-14 17-47-49 woman-8204525_1920 with a Quick Effect A (Fragment Blur) (abstr.mode=LAYER_MODE_SCREEN.jpg
2023-10-14 17-47-49 woman-8204525_1920 with a Quick Effect A (Fragment Blur) (abstr.mode=LAYER_MODE_SCREEN.jpg [ 560.77 KiB | Viewed 61200 times ]
PostPosted: Mon Oct 16, 2023 1:57 am  (#5)
:paint
2023-10-14 17-51-03 stream-6604669_1920 with a Quick Effect B (Blur Splinter (abstr.mode=LAYER_MODE_DISSOLVE.jpg
2023-10-14 17-51-03 stream-6604669_1920 with a Quick Effect B (Blur Splinter (abstr.mode=LAYER_MODE_DISSOLVE.jpg [ 1.53 MiB | Viewed 61199 times ]
2023-10-14 17-52-14 tree-3240922_1920 with a Quick Effect C (Blur Angular) (abstr.mode=LAYER_MODE_DODGE.jpg
2023-10-14 17-52-14 tree-3240922_1920 with a Quick Effect C (Blur Angular) (abstr.mode=LAYER_MODE_DODGE.jpg [ 1.31 MiB | Viewed 61199 times ]
2023-10-14 17-53-25 valencia-4791102_1920 with a Quick Effect D (Blur Gaussian) (abstr.mode=LAYER_MODE_MERGE.jpg
2023-10-14 17-53-25 valencia-4791102_1920 with a Quick Effect D (Blur Gaussian) (abstr.mode=LAYER_MODE_MERGE.jpg [ 831.09 KiB | Viewed 61199 times ]
PostPosted: Mon Oct 16, 2023 1:58 am  (#6)
2023-10-14 18-01-21 mules-4153342_1920 with a Quick Effect I (Triangular Pattern) (abstr.mode=LAYER_MODE_GRAIN_MERGE.jpg
2023-10-14 18-01-21 mules-4153342_1920 with a Quick Effect I (Triangular Pattern) (abstr.mode=LAYER_MODE_GRAIN_MERGE.jpg [ 1.1 MiB | Viewed 61196 times ]
2023-10-14 17-55-02 portrait-3258677_1920 with a Quick Effect E (Mess with Bits) (abstr.mode=LAYER_MODE_SCREEN.jpg
2023-10-14 17-55-02 portrait-3258677_1920 with a Quick Effect E (Mess with Bits) (abstr.mode=LAYER_MODE_SCREEN.jpg [ 1.16 MiB | Viewed 61196 times ]
2023-10-14 17-56-16 sprouts-5136126_1920 with a Quick Effect F (Blur Radial) (abstr.mode=LAYER_MODE_HSL_COLOR.jpg
2023-10-14 17-56-16 sprouts-5136126_1920 with a Quick Effect F (Blur Radial) (abstr.mode=LAYER_MODE_HSL_COLOR.jpg [ 863.66 KiB | Viewed 61196 times ]
PostPosted: Mon Oct 16, 2023 1:59 am  (#7)
:paint
2023-10-14 18-02-30 oak-354641_1920 with a Quick Effect J (Circle Art) (abstr.mode=LAYER_MODE_PIN_LIGHT.jpg
2023-10-14 18-02-30 oak-354641_1920 with a Quick Effect J (Circle Art) (abstr.mode=LAYER_MODE_PIN_LIGHT.jpg [ 781.6 KiB | Viewed 61195 times ]
2023-10-14 17-57-21 stream-5429113_1920 with a Quick Effect G (Twirl) (abstr.mode=LAYER_MODE_GRAIN_MERGE.jpg
2023-10-14 17-57-21 stream-5429113_1920 with a Quick Effect G (Twirl) (abstr.mode=LAYER_MODE_GRAIN_MERGE.jpg [ 1.07 MiB | Viewed 61195 times ]
2023-10-14 17-59-07 stream-5429113_1920 with a Quick Effect H (Textured Glass) (abstr.mode=LAYER_MODE_HSL_COLOR.jpg
2023-10-14 17-59-07 stream-5429113_1920 with a Quick Effect H (Textured Glass) (abstr.mode=LAYER_MODE_HSL_COLOR.jpg [ 1.33 MiB | Viewed 61195 times ]
PostPosted: Mon Oct 16, 2023 2:00 am  (#8)
I like a lot your first 3, very close to the idea of "abstract".
:paint :paint :paint
PostPosted: Mon Oct 16, 2023 2:00 am  (#9)
...but in the meantime you posted other ones very abstract too, great !!!
PostPosted: Mon Oct 16, 2023 2:02 am  (#10)
Thanks Dinasset, :hi5
2023-10-14 18-12-11 mountain-village-113508_1920 with a Quick Effect N (Random Gradient) (abstr.mode=LAYER_MODE_MERGE.jpg
2023-10-14 18-12-11 mountain-village-113508_1920 with a Quick Effect N (Random Gradient) (abstr.mode=LAYER_MODE_MERGE.jpg [ 1.04 MiB | Viewed 61193 times ]
2023-10-14 18-13-52 houses-6527892_1920 with a Quick Effect O (Hypotrochoid) (abstr.mode=LAYER_MODE_PIN_LIGHT.jpg
2023-10-14 18-13-52 houses-6527892_1920 with a Quick Effect O (Hypotrochoid) (abstr.mode=LAYER_MODE_PIN_LIGHT.jpg [ 893.02 KiB | Viewed 61193 times ]
2023-10-14 18-15-09 iceland-4475929_1920 with a Quick Effect P (KittyRings) (abstr.mode=LAYER_MODE_SOFTLIGHT.jpg
2023-10-14 18-15-09 iceland-4475929_1920 with a Quick Effect P (KittyRings) (abstr.mode=LAYER_MODE_SOFTLIGHT.jpg [ 675.02 KiB | Viewed 61193 times ]
PostPosted: Mon Oct 16, 2023 2:03 am  (#11)
:paint
2023-10-14 18-04-49 philippines-105177_1920 with a Quick Effect K (Disco) (abstr.mode=LAYER_MODE_PIN_LIGHT.jpg
2023-10-14 18-04-49 philippines-105177_1920 with a Quick Effect K (Disco) (abstr.mode=LAYER_MODE_PIN_LIGHT.jpg [ 1.02 MiB | Viewed 60801 times ]
2023-10-14 18-07-22 mountain-village-3713854_1920 with a Quick Effect L (Memoakten Algorithm A) (abstr.mode=LAYER_MODE_GRAIN_MERGE.jpg
2023-10-14 18-07-22 mountain-village-3713854_1920 with a Quick Effect L (Memoakten Algorithm A) (abstr.mode=LAYER_MODE_GRAIN_MERGE.jpg [ 1.08 MiB | Viewed 60801 times ]
PostPosted: Mon Oct 16, 2023 2:04 am  (#12)
:paint
2023-10-14 18-16-28 lake-4152201_1920 with a Quick Effect Q (Lissajous) (abstr.mode=LAYER_MODE_HARDLIGHT.jpg
2023-10-14 18-16-28 lake-4152201_1920 with a Quick Effect Q (Lissajous) (abstr.mode=LAYER_MODE_HARDLIGHT.jpg [ 1.01 MiB | Viewed 60801 times ]
2023-10-14 18-21-02 flower-8202753_1920 with a Quick Effect T (Plasma) (abstr.mode=LAYER_MODE_HARDLIGHT.jpg
2023-10-14 18-21-02 flower-8202753_1920 with a Quick Effect T (Plasma) (abstr.mode=LAYER_MODE_HARDLIGHT.jpg [ 456.44 KiB | Viewed 60801 times ]
2023-10-14 18-22-38 lake-5972924_1920 with a Quick Effect T (Plasma) (abstr.mode=LAYER_MODE_GRAIN_MERGE.jpg
2023-10-14 18-22-38 lake-5972924_1920 with a Quick Effect T (Plasma) (abstr.mode=LAYER_MODE_GRAIN_MERGE.jpg [ 803.86 KiB | Viewed 60801 times ]
PostPosted: Mon Oct 16, 2023 2:05 am  (#13)
:paint
2023-10-14 18-26-30 city-7847987_1920 with a Quick Effect V (Shadebobs) (abstr.mode=LAYER_MODE_SOFTLIGHT.jpg
2023-10-14 18-26-30 city-7847987_1920 with a Quick Effect V (Shadebobs) (abstr.mode=LAYER_MODE_SOFTLIGHT.jpg [ 795.23 KiB | Viewed 60801 times ]
2023-10-14 18-27-37 croatia-238324_1920 with a Quick Effect W (SpiralRGB) (abstr.mode=LAYER_MODE_SOFTLIGHT.jpg
2023-10-14 18-27-37 croatia-238324_1920 with a Quick Effect W (SpiralRGB) (abstr.mode=LAYER_MODE_SOFTLIGHT.jpg [ 913.65 KiB | Viewed 60801 times ]
2023-10-14 18-28-46 fishing-village-128519_1920 with a Quick Effect X (Turbulence) (abstr.mode=LAYER_MODE_SCREEN.jpg
2023-10-14 18-28-46 fishing-village-128519_1920 with a Quick Effect X (Turbulence) (abstr.mode=LAYER_MODE_SCREEN.jpg [ 604.71 KiB | Viewed 60801 times ]
PostPosted: Mon Oct 16, 2023 2:06 am  (#14)
:cool
2023-10-14 20-35-00 IMG_8463 with a Quick Effect C (Blur Angular) (abstr.mode=LAYER_MODE_MERGE.JPG
2023-10-14 20-35-00 IMG_8463 with a Quick Effect C (Blur Angular) (abstr.mode=LAYER_MODE_MERGE.JPG [ 1.6 MiB | Viewed 60801 times ]
2023-10-14 20-37-11 lighthouse-6570322_1920 with a Quick Effect D (Blur Gaussian) (abstr.mode=LAYER_MODE_HSL_COLOR.jpg
2023-10-14 20-37-11 lighthouse-6570322_1920 with a Quick Effect D (Blur Gaussian) (abstr.mode=LAYER_MODE_HSL_COLOR.jpg [ 772.07 KiB | Viewed 60801 times ]
2023-10-14 20-38-06 Lugo_AncientWall with a Quick Effect E (Mess with Bits) (abstr.mode=LAYER_MODE_LCH_COLOR.JPG
2023-10-14 20-38-06 Lugo_AncientWall with a Quick Effect E (Mess with Bits) (abstr.mode=LAYER_MODE_LCH_COLOR.JPG [ 1.18 MiB | Viewed 60801 times ]
PostPosted: Mon Oct 16, 2023 2:08 am  (#15)
2023-10-14 18-30-21 bay-of-islands-2152066_1920 with a Quick Effect Y (Twisted_Rays) (abstr.mode=LAYER_MODE_GRAIN_MERGE.jpg
2023-10-14 18-30-21 bay-of-islands-2152066_1920 with a Quick Effect Y (Twisted_Rays) (abstr.mode=LAYER_MODE_GRAIN_MERGE.jpg [ 494.13 KiB | Viewed 60801 times ]
2023-10-14 18-31-44 beach-1236581_1920 with a Quick Effect U (PrNoise) (abstr.mode=LAYER_MODE_SCREEN.jpg
2023-10-14 18-31-44 beach-1236581_1920 with a Quick Effect U (PrNoise) (abstr.mode=LAYER_MODE_SCREEN.jpg [ 1.23 MiB | Viewed 60801 times ]
2023-10-14 18-33-26 boat-4269040_1920 with a Quick Effect Z (Wiremap) (abstr.mode=LAYER_MODE_SCREEN.jpg
2023-10-14 18-33-26 boat-4269040_1920 with a Quick Effect Z (Wiremap) (abstr.mode=LAYER_MODE_SCREEN.jpg [ 1.3 MiB | Viewed 60801 times ]
PostPosted: Mon Oct 16, 2023 2:09 am  (#16)
:paint
2023-10-14 20-29-02 PHOTO-2023-07-09-10-37-02 with a Quick Effect A (Fragment Blur) (abstr.mode=LAYER_MODE_SCREEN.jpg
2023-10-14 20-29-02 PHOTO-2023-07-09-10-37-02 with a Quick Effect A (Fragment Blur) (abstr.mode=LAYER_MODE_SCREEN.jpg [ 575.72 KiB | Viewed 60801 times ]
2023-10-14 20-31-20 outdoors-7213961_1280 with a Quick Effect P (KittyRings) (abstr.mode=LAYER_MODE_SCREEN.jpg
2023-10-14 20-31-20 outdoors-7213961_1280 with a Quick Effect P (KittyRings) (abstr.mode=LAYER_MODE_SCREEN.jpg [ 536.59 KiB | Viewed 60801 times ]
2023-10-14 20-33-10 Paisaje-Montaña with a Quick Effect B (Blur Splinter (abstr.mode=LAYER_MODE_NORMAL.JPG
2023-10-14 20-33-10 Paisaje-Montaña with a Quick Effect B (Blur Splinter (abstr.mode=LAYER_MODE_NORMAL.JPG [ 1.42 MiB | Viewed 60801 times ]
PostPosted: Mon Oct 16, 2023 2:09 am  (#17)
2023-10-14 20-41-27 geese-7898732_1280 with a Quick Effect F (Blur Radial) (abstr.mode=LAYER_MODE_PIN_LIGHT.jpg
2023-10-14 20-41-27 geese-7898732_1280 with a Quick Effect F (Blur Radial) (abstr.mode=LAYER_MODE_PIN_LIGHT.jpg [ 1.16 MiB | Viewed 60801 times ]
2023-10-14 20-43-36 IMG_1386_with a Quick Effect I (Triangular Pattern) (abstr.mode=LAYER_MODE_HARDLIGHT.JPG
2023-10-14 20-43-36 IMG_1386_with a Quick Effect I (Triangular Pattern) (abstr.mode=LAYER_MODE_HARDLIGHT.JPG [ 1.03 MiB | Viewed 60801 times ]
2023-10-14 20-46-51 de4bdfc3b43cce2f66a33ba34f0bee05--guadalajara with a Quick Effect H (Textured Glass) (abstr.mode=LAYER_MODE_HARDLIGHT.jpg
2023-10-14 20-46-51 de4bdfc3b43cce2f66a33ba34f0bee05--guadalajara with a Quick Effect H (Textured Glass) (abstr.mode=LAYER_MODE_HARDLIGHT.jpg [ 1.33 MiB | Viewed 60801 times ]
PostPosted: Mon Oct 16, 2023 2:10 am  (#18)
:paint
2023-10-14 20-50-49 cherry-blossoms-7927688_1280 with a Quick Effect K (Disco) (abstr.mode=LAYER_MODE_HSL_COLOR.jpg
2023-10-14 20-50-49 cherry-blossoms-7927688_1280 with a Quick Effect K (Disco) (abstr.mode=LAYER_MODE_HSL_COLOR.jpg [ 673.74 KiB | Viewed 60801 times ]
2023-10-14 20-49-29 door-8029228_1920 with a Quick Effect J (Circle Art) (abstr.mode=LAYER_MODE_HSL_COLOR.jpg
2023-10-14 20-49-29 door-8029228_1920 with a Quick Effect J (Circle Art) (abstr.mode=LAYER_MODE_HSL_COLOR.jpg [ 844.29 KiB | Viewed 60801 times ]
2023-10-14 20-51-55 d086c0cb-f001-4197-a59a-58c72e7112e5 with a Quick Effect L (Memoakten Algorithm A) (abstr.mode=LAYER_MODE_LCH_COLOR.JPG
2023-10-14 20-51-55 d086c0cb-f001-4197-a59a-58c72e7112e5 with a Quick Effect L (Memoakten Algorithm A) (abstr.mode=LAYER_MODE_LCH_COLOR.JPG [ 735.21 KiB | Viewed 60801 times ]
PostPosted: Mon Oct 16, 2023 2:11 am  (#19)
2023-10-14 20-53-04 daisies-3439573_1280 with a Quick Effect M (Corner Gradient) (abstr.mode=LAYER_MODE_MERGE.jpg
2023-10-14 20-53-04 daisies-3439573_1280 with a Quick Effect M (Corner Gradient) (abstr.mode=LAYER_MODE_MERGE.jpg [ 828.78 KiB | Viewed 60801 times ]
2023-10-14 20-55-07 castle-7421039_640 with a Quick Effect N (Random Gradient) (abstr.mode=LAYER_MODE_HARDLIGHT.jpg
2023-10-14 20-55-07 castle-7421039_640 with a Quick Effect N (Random Gradient) (abstr.mode=LAYER_MODE_HARDLIGHT.jpg [ 1.04 MiB | Viewed 60801 times ]
2023-10-14 20-56-26 cat-8130334_1920 with a Quick Effect O (Hypotrochoid) (abstr.mode=LAYER_MODE_SOFTLIGHT.jpg
2023-10-14 20-56-26 cat-8130334_1920 with a Quick Effect O (Hypotrochoid) (abstr.mode=LAYER_MODE_SOFTLIGHT.jpg [ 723.5 KiB | Viewed 60801 times ]
PostPosted: Mon Oct 16, 2023 2:12 am  (#20)
2023-10-14 20-57-40 cc35652b-39ec-4fa5-9beb-8743ba1ecfa5 with a Quick Effect Q (Lissajous) (abstr.mode=LAYER_MODE_PIN_LIGHT.JPG
2023-10-14 20-57-40 cc35652b-39ec-4fa5-9beb-8743ba1ecfa5 with a Quick Effect Q (Lissajous) (abstr.mode=LAYER_MODE_PIN_LIGHT.JPG [ 1.08 MiB | Viewed 60801 times ]
2023-10-14 21-05-29 ca4e9f42-5941-4144-b897-cd6d8142b669 with a Quick Effect U (PrNoise) (abstr.mode=LAYER_MODE_SOFTLIGHT.JPG
2023-10-14 21-05-29 ca4e9f42-5941-4144-b897-cd6d8142b669 with a Quick Effect U (PrNoise) (abstr.mode=LAYER_MODE_SOFTLIGHT.JPG [ 1.4 MiB | Viewed 60801 times ]
2023-10-14 21-07-31 ba69cdc4cff44dd7b1c7428079d7c22d with a Quick Effect V (Shadebobs) (abstr.mode=LAYER_MODE_PIN_LIGHT.jpg
2023-10-14 21-07-31 ba69cdc4cff44dd7b1c7428079d7c22d with a Quick Effect V (Shadebobs) (abstr.mode=LAYER_MODE_PIN_LIGHT.jpg [ 956.54 KiB | Viewed 60801 times ]
