@ Molly
i first used gmic "pencil" then ,mostly to break the pattern that the filter may create where the original has a solid color, i used Kuwahara with very moderate setting (1 iteration and 2 of radius ) so that pattern was breaked in splats but the main outline and details were preserved
i think i should clear about the "pattern" i don't like
Here the pattern is quite cisible on the black brunch of the tree, on top, mostly on the right , and is even quite visible on the grey area just below the brunch, on the other hand the ape and the rest of the tree looks fine and detailed
Here that pattern is "broken" by the kuwahara effect ,
but the main details are preserved
