It is currently Fri Nov 20, 2026 9:58 pm
 Post subject: NEW COMPUTER-NEW GIMP INSTALLATION
PostPosted: Sat Jan 13, 2024 7:16 am  (#1)
I installed gimp on my new computer,but I can't find the folders in the zipped folder I have my explanation and some prints to clarify the problem
can anyone help me, thanks in advance gimper66
I started a new computer.zip [1.48 MiB]
Downloaded 139 times
 Post subject: Re: NEW COMPUTER-NEW GIMP INSTALLATION
PostPosted: Sat Jan 13, 2024 7:45 am  (#2)
Not sure what folders you're looking for.
I am on windows btw.
But here's my GIMP's folders Image
And here's my GIMP's Roaming folders Image
If you're looking for where the plug-ins folder is you can go to GIMP -> Edit -> Preferences and then Folders and expand that to see more.
PostPosted: Sat Jan 13, 2024 8:59 am  (#3)
the problem is solved, I didn't have the app data,
I had to go to explorer - SHOW - HIDDEN ITEMS - close explorer and open it again and then go to this computer etc etc... and everything runs perfectly now.
sincere greetings,gimper66
PostPosted: Sat Jan 13, 2024 10:07 am  (#4)
