It is currently Fri Nov 20, 2026 5:41 pm
 Post subject: The Juggler
PostPosted: Tue May 11, 2010 10:52 pm  (#1)
I did not make this but I'd bet we could figure out how to do it. I think it was a movie that was wider and the artist drew the stick figure by kind of tracing the real one but making a stick figure, starting about half way across, then deleted the actual movie from it. It's a fun thing to think about.
 Post subject: Re: The Juggler
PostPosted: Wed May 12, 2010 3:48 am  (#2)
Oregonian wrote:
I did not make this but I'd bet we could figure out how to do it. I think it was a movie that was wider and the artist drew the stick figure starting about half way across, then deleted the actual movie from it. It's a fun thing to think about.
I'd say FencePost (Art) knows how to do it. :yesnod
PostPosted: Wed May 12, 2010 8:15 pm  (#3)
That is really cool!
PostPosted: Thu May 20, 2010 10:15 am  (#4)
I am not familiar with this stuff, but is it possible to combine a flash file with a GIF? If so, this could be the outcome. It would make more sense if you could put both together, but like I said, I am not a genius on this stuff.
PostPosted: Wed Jun 13, 2012 6:44 pm  (#5)
Sorry - I just had to dig this one up. It is so brilliant! :)
PostPosted: Wed Jun 13, 2012 9:11 pm  (#6)
now this would be an awesome tutorial...especially for the gimp magazine!
PostPosted: Thu Jun 14, 2012 6:38 am  (#7)
really brilliant and should be not too complex
PostPosted: Thu Jun 14, 2012 7:03 am  (#8)
Pivot StickFigure animator and a gif would probably combine real well for this. :)
PostPosted: Sat Jun 16, 2012 1:11 am  (#9)
I need a program like Pivot! I wonder if it runs on Wine.
PostPosted: Sat Jun 16, 2012 7:55 am  (#10)
Here are three i use. Wine should work with at least one of these programs. :)
http://www.makeuseof.com/tag/3-free-sti ... on-career/
Wine compatible Tisfat here
http://www.iwasdeportedandalligotwasthi ... at0684.zip
PostPosted: Sat Jun 16, 2012 9:32 am  (#11)
tisfat looks really cool, if only I had the time to learn how to use and play with it!
PostPosted: Mon Oct 10, 2016 8:51 am  (#12)
Pivot is fun to play with. Forgot all about stick figure animations. :)
PostPosted: Mon Oct 10, 2016 3:06 pm  (#13)
Did anyone figure out how to do the task posed in post #1?
PostPosted: Mon Oct 10, 2016 3:48 pm  (#14)
then open that .gif and trace the layers. and remove the original content of where you traced and you have yourself this kind of traced animated movie.
Here's a sample .gif found on the net.
And then I just put a guide in the middle and traced each frame and deleted content and i have this.
PS: Thank god the example above only had 8 frames, otherwise I don't think i would have the patience to do it.
