It is currently Thu Nov 19, 2026 1:31 pm
 Post subject: SOLVED now ! (was "ARRGGHH , delusions ..)
PostPosted: Tue Jul 05, 2011 5:24 am  (#1)
EDIT
solved now the filter is working again and is available by refreshing the gmic filters
the ARGGHH because the filter, my last the SteamPunk pencil 2, is still broken, now in my local copy to be broken is only the preview, i fear i must ask help to fix or at least to decipher the misterious error message.
so the sucess is only for the results even with a still broken preview
well here just to show how the image size modify the final result, here i used similar setting setting but the first was first scaled down then edited, while second image was edited at original size (about the double, was 1600 wide ) and then scaled down
graduated by PhotoComiX, on Flickr
Graduated ! by PhotoComiX, on Flickr
ORIGINAL
HallmanGradHoriz1 by US Army Africa, on Flickr
so at soon the preview will be fixed all this will be available
BW
castoro by PhotoComiX, on Flickr
or
Color
castoro-color by PhotoComiX, on Flickr
ORIGINAL
Wadda ya mean, I need a bath!!! by law_keven, on Flickr
But i still want add a last option, i show it now
i may already get this
2 by PhotoComiX, on Flickr
or something a bit more abstract like this, call this 2
4 by PhotoComiX, on Flickr
Now i want turn 2 in this
yes by PhotoComiX, on Flickr
where the difference is a edge layer (gradient norm on the original) on top in screen mode
The problem to automatize is that for a nice effect in the edge layer most of gray should become fully black (without concern for clipping) and only the whitest pixels preserved, quite easy do manually but i still have problem to automatize it.
humm maybe i may just create and then call a preset for curve or level...
and to fix the preview
 Post subject: Re: ARRGGHH , delusions and success
PostPosted: Tue Jul 05, 2011 5:32 am  (#2)
Also this come out fine
Ethiopian girl by PhotoComiX, on Flickr
ORIGINAL
Ethiopia by babasteve, on Flickr
PostPosted: Tue Jul 05, 2011 6:07 am  (#3)
Very nice PC.......
PostPosted: Tue Jul 05, 2011 6:44 am  (#4)
gorgeous effect!!
 Post subject: Re: SOLVED now ! (was "ARRGGHH , delusions ..)
PostPosted: Wed Jul 06, 2011 5:44 pm  (#5)
:drum SOLVED NOW :spring !! :drum
2 weeks lost and the only problem in the code was a missing "-" :bawl , but anyway i am glad to have solved
I was just posting a help request for David and the gmic group, then before click submit, i decided to give a last look and ... :wow that solved!
Now after so much delay i will go for the color version :keybdtype
PostPosted: Wed Jul 06, 2011 6:25 pm  (#6)
that is so cute. Go for it PC.........
PostPosted: Wed Jul 06, 2011 7:12 pm  (#7)
thank Molly !!
PostPosted: Wed Jul 06, 2011 7:31 pm  (#8)
Nicely done PC! :)
PostPosted: Wed Jul 06, 2011 7:51 pm  (#9)
Keep on keeping on, PhotoComix. You've come up with great stuff. :paint
A single missing "-" is pretty hard to track down. Good job! :hi5
