It is currently Thu Nov 19, 2026 12:51 pm
 Post subject: Enter Gimp Space Button
PostPosted: Thu Jul 14, 2011 1:07 am  (#1)
 Post subject: Re: Enter Gimp Space Button
PostPosted: Thu Jul 14, 2011 1:23 am  (#2)
Love the metal gradient texture, Rod. Are you going to bevel the text anymore or leave it as is?
PostPosted: Thu Jul 14, 2011 6:13 am  (#3)
Great new Shortcut Icon for GIMP :D
I'm back I think
PostPosted: Thu Jul 14, 2011 10:28 am  (#4)
The gradient i created myself and added some noise.The indent can be created by selecting the area you want copy/paste ... layer flip vertical. :)
The small screw looking areas are just two inverted L shapes blurred by 1-2 then copy it and merge those together then copy those two and slide them over.
I am probably going to experiment some with dd's beveler to see if i can get a good looking icon text.Crisp, and clear.
Great idea to make it a shortcut to Gimp Willy. :)
PostPosted: Thu Jul 14, 2011 11:19 am  (#5)
That is really cool. I love all the metal details in it. Nice work, Rod!
PostPosted: Thu Jul 14, 2011 3:15 pm  (#6)
Thanks O. :)
Here is one i created a while back.This one is actually on my website in Image gallery #4.
PostPosted: Thu Jul 14, 2011 3:48 pm  (#7)
so you can make this to use as your gimp desktop icon?
PostPosted: Thu Jul 14, 2011 5:50 pm  (#8)
Sure just create it in Gimp and save as your icon extension...mine is ico on Windows.
But i use RocketDock and PNG images because it auto sizes the PNG image to the correct size.Which i like because i can make it huge and at a small size its nice and crisp.Especially if it is made in Inkscape. :)
