It is currently Thu Nov 19, 2026 3:21 am
 Post subject: 3D circular design
PostPosted: Thu Feb 12, 2026 12:55 pm  (#1)
Hi I created a 3D looking circle
Also created another using the same princile
 Post subject: Re: 3D circular design
PostPosted: Thu Feb 12, 2026 1:09 pm  (#2)
Thanks for sharing. Can you also share how you did this? For those who might be interested.
PostPosted: Thu Feb 12, 2026 1:30 pm  (#3)
Hi Jappaloe63. My post has been flagged as spamy when I try to add the link.
I do have a youtube link to the tutorial. I can gladly share.
PostPosted: Fri Feb 13, 2026 4:56 am  (#4)
Just make two more posts to bring them up to 5 then you can add a link. (Maybe reply to a few posts)
PostPosted: Sun Feb 15, 2026 1:51 pm  (#5)
Hi This is the GIMP channel link to the video. Regards
https://www.youtube.com/playlist?list=P ... J5Q0hlo2fg
PostPosted: Mon Feb 16, 2026 5:48 am  (#6)
Thanks for the link. I'll try to do it. :)
PostPosted: Tue Feb 17, 2026 9:17 pm  (#7)
Thank you very much, will have to try also.
PostPosted: Wed Feb 18, 2026 5:45 am  (#8)
:tyspin Thank you!
PostPosted: Thu Feb 19, 2026 1:28 am  (#9)
Before you posted your link I found a hand drawn one that was similar to yours, which I followed. I didn't know how to colour though until you showed us. This is pretty rough. I will try to do another following yours.
PostPosted: Thu Feb 19, 2026 11:50 am  (#10)
Thanks for your tutorial. It's very interesting. I've learned new methods.
Here my first try. :)
PostPosted: Thu Feb 19, 2026 8:41 pm  (#11)
Very nice Issabella. :)
Tried it several times & I keep getting stuck :( . Cant do a proper gradient and since vs 3 has all the lock options I am not sure which to use. When I eventually got something to move only one layer moved not two even though I had two locked :gaah
PostPosted: Thu Feb 19, 2026 11:23 pm  (#12)
Just exploring these shapes created by connag and in doing so I found a different way of creating similar shapes.
I used two concentric circular paths, which basically defined the width of the final shapes, and two centred hexagon shaped paths intersecting with both the inner and outer circles.
The points of intersection on the two circular paths gave me the start, end and mid points for a new path, from which I could create the target shapes as shown below. I then used one of my gradients to finish off these shapes. Obviously appropriate rendering can be used to emphasise a 3D view.
PostPosted: Fri Feb 20, 2026 5:10 am  (#13)
Not as nice as connag's graphic but all sorts of ways to get a repeating shape in a circle.
This using the gmic rotate filter and more than a bit of serendipity - never quite sure of the outcome.
...and a 3 minute video to go with that: https://youtu.be/urjL6iIChK0
PostPosted: Sat Feb 21, 2026 3:15 am  (#14)
rich, my first try with your method in your tutorial. No good but I'll try it again. Thank you so much.
PostPosted: Sat Feb 21, 2026 3:43 am  (#15)
Oh dear, It is meant for the odd spare 10 minutes and a bit of doodling ;) Do not like the result ? Then scrap it and try again when you have another spare few minutes.
You can of course, tweak the layers. The batcher plugin will apply to each layer (or you could use gmic - that applies to all layers). This one with batcher and a bevel.
PostPosted: Sat Feb 21, 2026 4:00 am  (#16)
Sorry. I meant to say that mine didn't turn out as well as yours. :)
But I really like the technique. and this last yours is very nice, too. Thank you so much rich. :tyspin
I did another.
PostPosted: Sat Feb 21, 2026 4:30 am  (#17)
one more. :yes
PostPosted: Sat Feb 21, 2026 11:51 am  (#18)
I used RD' custom font, Skinnyhouse's Custom Font Trailing v0.4b and rich's tutorial. Of course, garagecoder in G'mic.
So, thank you so much.
PostPosted: Sun Feb 22, 2026 1:34 am  (#19)
Nice tutorial; skipped the guide stuff and just dupped/rotated and moved by eyeball and then did a dup, circular blur grain merge to taste. Can't let you guys have all the fun. lol
PostPosted: Sun Feb 22, 2026 1:47 am  (#20)
And, of course, I had to 2 pole Droste the result. lol
Thanks for the fun; need to now hit the hay for day 3 of my work week. :)
