It is currently Thu Nov 19, 2026 2:31 am
 Post subject: G'MIC-3D-Blocks
PostPosted: Sat Apr 04, 2026 9:21 pm  (#1)
Have not played with this G'MIC filter in quite a while. :) If anyone wants the preset for this result i will gladly attach it here.
Mostly just playing with Tilt, and x lighting. Of course there are other settings as well. :bigthup
 Post subject: Re: G'MIC-3D-Blocks
PostPosted: Sat Apr 04, 2026 11:14 pm  (#2)
Completely forgot about this preset, Rod. Your result came out fantastic by the way. :)
PostPosted: Sun Apr 05, 2026 1:30 am  (#3)
Thank you Lyle. :)
PostPosted: Sun Apr 05, 2026 1:46 am  (#4)
OK, Rod; you got me to play with 3D blocks once again (and did do some convolution tricks, so not quite all blocks). :)
https://live.staticflickr.com/65535/551 ... 03d1_o.jpg
PostPosted: Mon Apr 06, 2026 1:59 am  (#5)
Great results! Looks like you have been in a nasty boxing match and shattered some teeth. :) LOL
PostPosted: Tue Apr 07, 2026 1:30 am  (#6)
Cool guys. I thought I'd try another with a small pic. Dont know how long a large one would take on my computer now. I don't think I have done one of these since just after David brought it out.
PostPosted: Wed Apr 08, 2026 8:14 pm  (#7)
Not sure how old your PC is, Sallyanne, but it really doesn't take that long to run this particular filiter (unlike Packed Ellipse; lol). :)
PostPosted: Fri Apr 10, 2026 4:07 am  (#8)
PC is only 8 years old. Cant afford a new one yet. Here is a larger pic scaled to about 1/4 size.
PostPosted: Fri Apr 10, 2026 10:30 am  (#9)
This would look pretty awesome as a tiny planet i bet. :bigthup
PostPosted: Fri Apr 10, 2026 7:52 pm  (#10)
Used one of G'MIC's sample images for reference. I uprezzed and then duplicated. For the top layer, I ran depth map approximation to create the target for 3D Blocks. I then colorized using the Blend (Shape Average) preset David saved for me. Did some additional enhancements as well. :)
