It is currently Thu Nov 19, 2026 5:34 am
 Post subject: just monkeying around one night (couldnt sleep) =P
PostPosted: Thu May 20, 2010 9:45 pm  (#1)
i made this for my signature for Gimper.com
The large R then a hole with Wilbur for O, and the clock and watch hand for D ... ROD =)
Gimper Rod
and yes i did create the cube myself....well with the help of map object.
I did it dif than the tut though.Instead of creating a checker board, i set my view grid at 100x100px and
created a first layer (300x300 px) white bg, and then created 9 new layers with the dif colored blocks, at 100x100 px 3 in a row.Then i just used the rectangular select tool at 100x100 px fixed and colored in the selections one by one.
only problem i had was rendering it in the map object at 300x300 kept stalling the plugin...*sigh*..so i changed that value to 150x150 and it worked great.
then i just rotated the image of the cube to fit in my rendered fingers image...worked pretty well.
probably what i should have done is created it real huge first then scaled it down after i merged the visible layers...oh well live and learn.
If your interested i can throw up a tut for it and paste a link to the xcf file.
actually i think i just posted the tut...lol =P
 Post subject: Re: just monkeying around one night (couldnt sleep) =P
PostPosted: Thu May 20, 2010 10:11 pm  (#2)
That's cool, Rod. Kinda like a GIMP Picasso there without the sagging.
Keep on using those sleepless nights for good stuff like this. Sure beats counting sheep.
PostPosted: Thu May 20, 2010 10:51 pm  (#3)
i created another one and kept all the xcf info...here is the finished result after fixing two of the cubes that were the same color on two sides , its a lttle jaggy edged but that can be fixed pretty easy.
thx Oregonian for the kind comments.
PostPosted: Thu May 20, 2010 10:54 pm  (#4)
lol i just noticed i have 2 red and white cubes heheheh
maybe i should go get some sleep
fixed! =)
PostPosted: Thu May 20, 2010 11:05 pm  (#5)
Just a note to you, Rod. In Gimp Chat you can upload images directly into Gimp Chat's image upload site. No need to go to Image Shack or any of the other upload sites. I re-uploaded your Rubik's cube to the Gimp Chat upload site.
Take a look here about how to do it. Be sure to ask questions if you have any.
PostPosted: Thu May 20, 2010 11:08 pm  (#6)
cool deal, thanks!
PostPosted: Thu May 20, 2010 11:13 pm  (#7)
We must have been working on Rubik's cube at the same time. I no sooner had it changed than the new one appeared.
Anyway, the new, best one has been uploaded to Gimp Chat's upload site.
I've also uploaded your sig picture in the first post. :-D
You may call me, O. It's much faster than typing Oregonian (it's really a spelling test).
PostPosted: Fri May 21, 2010 5:22 am  (#8)
Love your sig "O"......
PostPosted: Fri May 21, 2010 12:14 pm  (#9)
Thanks, Molly. It's my first apng sig. :)
PostPosted: Fri May 21, 2010 11:57 pm  (#10)
alrighty O it is then =)
my first animation was of a byplane landing, and i must mention was very, very icky!
LOL
PostPosted: Sat May 22, 2010 12:20 am  (#11)
LOL
Was it the one in Akkana Peck's book, Beginning GIMP - From Novice to Professional?
I never was brave enough to try that one.
PostPosted: Sat May 22, 2010 2:37 am  (#12)
yup same tutorial =)
here is my finished landing...good thing i have no pilots license.
PostPosted: Sat May 22, 2010 4:40 am  (#13)
very nice ROD.....
PostPosted: Sat May 22, 2010 5:06 am  (#14)
kind of makes you dizzy if you watch it too long though. =P
thanks Molly
wow that is really bright! *hides eyes*
