It is currently Thu Nov 19, 2026 5:32 am
 Post subject: A U.S. Checkpoint image I am working on!
PostPosted: Fri May 21, 2010 4:56 pm  (#1)
Hey everyone! This image that is below has taken me 2 1/2 hours to make. Again, I ask for full criticism! I know it needs work, and right now I am working on the sign on the left and the pole. Still stuff to do, and it is basically just an image I am making to make. I am very patriotic and if you haven't noticed, it is a U.S. Checkpoint located in the desert somewhere in Iraq. I hope nothing offends anyone on the site, and if so please report to an admin so they can remove. Thanks for looking nonetheless!
Here it is!
The things I know that need work on it are:
The sign on left
The stuff near it
I am really not to sure how I am going to do it, but I will re-post the finished or more advanced version.
The soldier looks blurry( I am not sure if it is because it is from a game. The size is actually larger than what it is in the image.)
Thanks,
M3SH
 Post subject: Re: A U.S. Checkpoint image I am working on!
PostPosted: Fri May 21, 2010 5:20 pm  (#2)
Are these objects all in layers?
If you turn off the soldier layer, notice the light source (sun) is hitting fully on this end of the building making the east side completely in shadow. So, as far as the sign goes, I would try to make the shadow with the same light source and also the pylon.
As far as the sign itself, I don't think you can mess much with the text unless you have an Iraq keyboard (lol)....Someone may be able to help you with a way to brighten it up though....
Thats all I can think of for now.....
PostPosted: Fri May 21, 2010 5:23 pm  (#3)
I like it but I think the soldier needs a shadow on the ground and also the cone. The light appears to be coming from the right on the soldier and cone. Think they would look more like they belonged to the image that way.
Working with shadows is definitely not something I know a lot about. Hopefully someone will come up with good suggestions for you.
Looks like Molly came up with some good suggestions while I was posting.
PostPosted: Fri May 21, 2010 5:26 pm  (#4)
This is the second version, I touched up the sign, also sharpened the soldier. Next I am going to mess with the shadows of it ALL. Thanks for the suggestions guys, I really do appreciate them.
Yes, Molly, they are in layers, most layers I have ever messed with.
PostPosted: Fri May 21, 2010 5:27 pm  (#5)
Your soldier definitely looks better. Good luck on those shadows.
PostPosted: Fri May 21, 2010 5:51 pm  (#6)
Okay here is the picture with the shadows. I just the Perspective tool until it looked decent, I still don't much care for the post and the shadow of cone and post. Any other suggestions?
PostPosted: Fri May 21, 2010 6:05 pm  (#7)
Very good, you are a fast learner. The reason I was asking about the layers cuz it is so much easier when you can turn the layers off you are not working on so you can see better where the lights and angles of the shadows are. I think the shadow on the pylon should be wider at the base but I can't help with the x's and y's cuz I am not sure myself how to set those up...
Did you go alpha to selection to select and do you shadows with filters > lights and shadows > drop shadow or did you draw them in.
PostPosted: Fri May 21, 2010 6:07 pm  (#8)
I did the Lights and shadows and more ctrl+Z lol, by pylon you mean cone right?
If so, I am having problems with the whole cone issue. The shadow isn't very good and it is bothering me how they come together, but when I move it around, it doesn't look so good.
PostPosted: Fri May 21, 2010 6:34 pm  (#9)
One other way is don't put any shadows in till you are finished and you save it as a png.... then you can do alpha to selection > filters > lights and shadows > drop shadow. fool with the x y and z's until you get the angle you want then try it. At least they will all be going the same direction..... Someone with more experience in setting those up could help you more there...
PostPosted: Fri May 21, 2010 6:38 pm  (#10)
I will start messing with that now, this is the finished image at this point. If you cannot see the change, on the sign I magnified it and colored in all the pixels that made it look to real. If you look closely you can see the change! Anyways, here it is and I hope you all like it!
PostPosted: Fri May 21, 2010 7:46 pm  (#11)
much better, although I think the shadows could be lighter, at least on the shadow edges. Also, there must be a way to make the bottom of the boots look more like they are on the ground. Somehow, the ground and the boots looks a bit unconnected. I don't know enough about art to know what would make it look more realistic.
PostPosted: Fri May 21, 2010 8:27 pm  (#12)
Yes I have to agree on the boots and ground, not sure how I will fix that but I will give it a go! Thanks!
