It is currently Thu Nov 19, 2026 1:30 pm
 Post subject: A GAP animation
PostPosted: Thu Jul 28, 2011 7:52 am  (#1)
My first one i actually created by myself! :)
A Gimp Chat Logo spinning around a transparent globe.
Maybe on my next one i can get the sharpness better.It is kind of fuzzy around the edges.
 Post subject: Re: A GAP animation
PostPosted: Thu Jul 28, 2011 8:26 am  (#2)
Cool Rod, Did you try shrinking 1 pixel around the edges?
PostPosted: Thu Jul 28, 2011 8:46 am  (#3)
Right now i am trying to save it as a animated png and see if that works. :)
Then i will try the shrink by 1 pixel method.
Good idea Molly.
PostPosted: Thu Jul 28, 2011 9:03 am  (#4)
Here it is.
No real difference in quality at all. :\
Your way Molly! :) - although i really didn't relish the idea of going through 31 layers with
Alpha to selection - select-shrink by 1pixel - select invert - delete took forever.
Perhaps someone could develop a script to accomplish this sort of task quicker?
Probably should have went with 2 pixels. :P
Oh well! - Back to the drawing Gimp. :paint
PostPosted: Thu Jul 28, 2011 9:43 am  (#5)
I meant to do it before you animated it Rod.... I wouldn't go through that many layers either. :teeth
PostPosted: Thu Jul 28, 2011 9:46 am  (#6)
lol - now you tell me. heheh.
Anyways did you notice both the pngs that i uploaded have a slight shift at the 2nd frame?
The GIF doesn't and that is weird.It seems like the PNG extension would replace the layers better than that.
Perhaps that is something that should be looked at by Max in the future?
PostPosted: Thu Jul 28, 2011 10:17 am  (#7)
Here it is.
Just to let you know, Rod, I got this message when I tried to view your images.
The image “http://www.gimpchat.com/files/196_Gimp-Chat-Globe2.png” cannot be displayed, because it contains errors.
I like your animation!
PostPosted: Thu Jul 28, 2011 10:34 am  (#8)
That is weird O because i can see them all. :)
Thanks for the comment.
PostPosted: Thu Jul 28, 2011 10:37 am  (#9)
All I see is the word, Image and when I right-click the word, I get that message.
PostPosted: Thu Jul 28, 2011 10:52 am  (#10)
Sounds like your APNG viewer isn't working. :)
I have no idea what that is by the way.
PostPosted: Thu Jul 28, 2011 10:53 am  (#11)
Wasn't that one of the problems with the newest FireFox?
PostPosted: Thu Jul 28, 2011 10:59 am  (#12)
Not with my Firefox. I can view the apng images here just fine. :mrgreen:
PostPosted: Thu Jul 28, 2011 11:11 am  (#13)
How come my png animations look so horrid?
I wonder if it is the way i saved them?
Something in the APNG dialog perhaps? (compression)
PostPosted: Thu Jul 28, 2011 11:23 am  (#14)
Nope tried to create it with less compression and it got worse. (If that's possible) :)
PostPosted: Thu Jul 28, 2011 11:34 am  (#15)
Here is the original image before i animated it.It must have happened using map object varying for GAP. :\
It should look pretty smooth using this image.
PostPosted: Thu Jul 28, 2011 11:39 am  (#16)
I can't see the apngs you posted at all. I just tried making an apng and my plug-in no longer works. Don't know why. Wonder if there's a new one out.
PostPosted: Thu Jul 28, 2011 11:57 am  (#17)
Here I am, quoting myself again. I tried another apng and it worked. Don't know why it didn't before.
This is what my png settings dialog looks like.
PostPosted: Thu Jul 28, 2011 12:32 pm  (#18)
Do you have a background with yours O cause mine do not have background's they are transparent.
Here is one i did with a background.
PostPosted: Thu Jul 28, 2011 12:33 pm  (#19)
Mine has a transparent bg.
PostPosted: Thu Jul 28, 2011 12:38 pm  (#20)
I can see both as well.
