It is currently Thu Nov 19, 2026 12:51 pm
 Post subject: Something fishy here!
PostPosted: Sat Jul 30, 2011 10:46 am  (#1)
 Post subject: Re: Something fishy here!
PostPosted: Sat Jul 30, 2011 11:02 am  (#2)
That's a totally fun picture, Rod! Nice! :bigthup
PostPosted: Sat Jul 30, 2011 11:04 am  (#3)
very nice...hows about a quick how to
PostPosted: Sat Jul 30, 2011 1:02 pm  (#4)
I used Slice, which is a Python plug-in, to cut up my image, 2-ton. Opened the slices as layers, then G'MIC > Artistic > Polaroid on each layer to make the framed images.
Original image.
PostPosted: Sat Jul 30, 2011 1:45 pm  (#5)
Very cool O. and Rod :yes
PostPosted: Sat Jul 30, 2011 1:50 pm  (#6)
LOL - is that a Farside cartoon O? -i love that comic. :)
I will throw a tutorial up in a day or so for the photo image 2-ton. :)
But basically it is
Make a rectangle (700 high by 650 wide)
Color it white -EDIT - color is off-white a bit. :)
Create another rectangle inside it that resembles the inside of the photo (the inside part of the white frame).
Delete that part.
Now you have your photo frame.Open any image and put it under this frame you made.
Duplicate the frame as many times as you want (how many photos you want lying there) - i did 6 i think.
Pile them and rotate them to your liking.Now figure out which ones you want layered where.
How will they be stacked on the image that is.Will this one be under that one ...ect ect
Now you have to erase the parts that will be under other photos - hidden underneath.
Then just merge all of them together and erase the part of the image underneath that is on the outside of the Merged frames layer.
Now add the edges using the pencil tool where the photos overlap.Set the opacity of that layer real low...just so its faint.
Now the image frames are done - merge everything together...open the same image and put it under everything.
Go to filters/distorts/mosaic - set the pieces to more color - bigger and squares and hexes.
Now you have the image tiled, and it should look the same as mine or close.
Just a rough tutorial.I will put a more detailed one up soon.
PostPosted: Sat Jul 30, 2011 9:26 pm  (#7)
I received the cartoon in an email. I'm pretty sure it is not a Far Side cartoon. I love Far Side Stuff. The Far Side calendar rocks - afaik it's still available every year. :hehe
http://stephhicks68.hubpages.com/hub/Gary-Larson
PostPosted: Mon Aug 01, 2011 7:32 am  (#8)
Heheheh... i love the Lone Ranger one. :)
This though is by far still my favorite and i still tease the cows when my Wife and i drive by some of them.
This is actually one of my splash screens for Gimp, and i would love to add more of them. :)
PostPosted: Mon Aug 01, 2011 7:51 am  (#9)
lol that is quite a role reversal...we/us, seen through the eyes of the cattle.
