It is currently Thu Nov 19, 2026 1:32 pm
 Post subject: something what went wrong
PostPosted: Tue Aug 09, 2011 11:29 am  (#1)
this didn't turn out the way i wanted it where did i go wrong?
 Post subject: Re: something what went wrong
PostPosted: Tue Aug 09, 2011 11:37 am  (#2)
What did you want to do?
PostPosted: Tue Aug 09, 2011 11:39 am  (#3)
lucy doesn't stand out like i want her to
PostPosted: Tue Aug 09, 2011 10:12 pm  (#4)
can you be more specific?
PostPosted: Wed Aug 10, 2011 8:29 pm  (#5)
that pic would be a good one to work on the tuts for removing background from fine hair strands.
PostPosted: Fri Aug 12, 2011 11:42 am  (#6)
I agree. :)
You can try duplicating the image and go to colors/invert and set the top layer to (i think divide).
If you are trying to make the colors stand out.
If you are going for a Sepia tone of color, try the Sepia plugin available on the registry.
http://registry.gimp.org/node/17159.
Or if you just want the lines or edges to stand out try the Filters/edges filters already available with Gimp-2.6.11.
Just duplicate your image and run one of the filters on the top layer and play with the layer modes and see what you get.
There is also sharpening tools available under Filters/Enhance.
