It is currently Thu Nov 19, 2026 2:14 pm
 Post subject: My First Rocket
PostPosted: Mon Sep 19, 2011 10:57 am  (#1)
Hi!
After seeing all the cool stuff you people make with GIMP, I just wanted to share my very first object (the rocket) I made from scratch using a PS tutorial. I had to adapt some of the steps but since I'm not proficient with either program, I made some of the steps up. ;)
Not happy with the gradients...I think they could be more intense but I can't figure out how to do that. I guess PS has a lot more settings available.
I saved the steps in layers so I should be able to go back and play with it a bit more.
 Post subject: Re: My First Rocket
PostPosted: Mon Sep 19, 2011 10:59 am  (#2)
That's very nice, oopsart!
PostPosted: Mon Sep 19, 2011 11:03 am  (#3)
As Molly would say "that's kewl" I like rockets. Here's a couple I made about 12 years ago but not with gimp.
PostPosted: Mon Sep 19, 2011 11:23 am  (#4)
Thanks, Oregonian!
And, Draconian...I think yours looks better. LOL!
PostPosted: Mon Sep 19, 2011 11:40 am  (#5)
oopsart wrote:
Hi!
Not bad! If you're trying to intensify the gradient, did you try creating your own gradient? You could move some sliders around and intensify the gradient quickly.
PostPosted: Mon Sep 19, 2011 11:46 am  (#6)
I'm so new to GIMP that I don't even know what that means. (off to find the sliders.....)
PostPosted: Mon Sep 19, 2011 12:14 pm  (#7)
Hehe, no sweat. Check the gradient's dockable dialog. For some information on how to find dockable dialogs check this video:
http://gimpedblog.blogspot.com/2011/09/ ... son-1.html
PostPosted: Mon Sep 19, 2011 12:17 pm  (#8)
Nice work, oops! You next step would be to animate the rocket in a flyby and pulse the engine flames. :bigthup
That's one BIG rocket, Drac. How high would that puppy get?
PostPosted: Mon Sep 19, 2011 12:19 pm  (#9)
Do you have a link to the tutorial you used, oopsart?
PostPosted: Mon Sep 19, 2011 12:41 pm  (#10)
Lauched near Waco, Tx with staged engine ignition, altimeter deployment package. Weight - 64.8 lbs on the pad, Altitude was 1.273 miles with 24" drogue chute at apogee and 18' military cargo chute deployment at 500'. It took me about 6 months to build, cost me around $75.00 for the propellant reload package to fly it one time. Don't get me started, I tend to go off a bit when it comes to my favorite hobby(other than gimp of course) Besides....this aint my thread and I think he did a fine job on his first rocket. Kudos to you dude!
File comment: Under main boost
File comment: second stage engine ignition
File comment: Under canopy at 500'
PostPosted: Mon Sep 19, 2011 12:58 pm  (#11)
looks rather cool I like it, it's got that cartoon effect :D You need to play about with gradients I love playing with them it's amazing what you can do with them. The cool thing I like about gradients is that you can make them your self you can use 2 or more combinations of colours.
PostPosted: Mon Sep 19, 2011 3:16 pm  (#12)
I like it, it looks good!
For the gradients, if you just want the colors to be richer, you could duplicate the layer and set the top one to a different layer mode (like overlay for example). Brightness and contrast will also bring out the colors.
Nice work, oopsie!
PostPosted: Mon Sep 19, 2011 3:24 pm  (#13)
Thanks! I didn't even know gradients have a dockable dialog.
PostPosted: Mon Sep 19, 2011 3:27 pm  (#14)
Hi mahvin!
Yes, although it's not specifically for the rocket but for a whole webpage.
Here is the link:
Rocket Tutorial
PostPosted: Mon Sep 19, 2011 3:30 pm  (#15)
Nice work, oopsie!
Thanks!
You know, I thought about the duplicating the layers step AFTER I posted the image (I live by Murphy's Laws).
I will have to try that later when I get home.
PostPosted: Mon Sep 19, 2011 3:33 pm  (#16)
Hi Lorri,
Yeah, I wanted a 'cartoony' rocket for a poster for the school where I work.
I just found out about the gradients and will play with them later...I just hope I saved the files correctly.
PostPosted: Tue Sep 20, 2011 2:17 am  (#17)
I managed it thanks and it's lovely you managed to sort out yours to. You have fun with it oppsart
