It is currently Thu Nov 19, 2026 3:02 pm
 Post subject: Baby step
PostPosted: Fri Sep 23, 2011 10:39 pm  (#1)
I think I am finally getting somewhere,thank s to ALL of You who helped me
thank you :tyspin :tyspin :tyspin
 Post subject: Re: Baby step
PostPosted: Fri Sep 23, 2011 11:13 pm  (#2)
Looking good. :)
PostPosted: Fri Sep 23, 2011 11:15 pm  (#3)
Rod,
Thank Yo for Your kindness :)
PostPosted: Sat Sep 24, 2011 3:47 am  (#4)
very good Pirate.
PostPosted: Sat Sep 24, 2011 10:05 am  (#5)
WTG Pirate! Looks like you are making great progress in GIMP. :gimp
PostPosted: Sat Sep 24, 2011 3:00 pm  (#6)
:ditto
Good job, Pirate.
PostPosted: Mon Sep 26, 2011 4:37 pm  (#7)
Thank You All for Your encouragements:)
so ,now You get punished because i am posting another one
PostPosted: Wed Oct 05, 2011 3:51 pm  (#8)
did a smoke background first,then added letters
but as usual i can't tell where it uploaded lol
PostPosted: Wed Oct 05, 2011 4:03 pm  (#9)
If you uploaded it in here, can you tell me the full name of the file such as myfile.png or whatever?
PostPosted: Wed Oct 05, 2011 4:09 pm  (#10)
Greetings pirate541.
I see that you uploaded and added an attachment as well.
Here's the image you uploaded.
Here is the screen you see when you upload an image directly to Gimp Chat.
The 3rd red box highlights the link to your uploaded image.
http://gimpchat.com/files/53_myimage.png
It will already be wrapped in image tags.
If clicking submit doesn't insert the image into the post, you'll need to copy and paste it into the post. Don't close down the dialog until you've inserted or copied the image or you won't know where it is located. :hehe
You can manage your attachments from the User Control Panel, under Manage Attachments.
PostPosted: Wed Oct 05, 2011 4:19 pm  (#11)
ok,Thank You for Your help and input :)
PostPosted: Wed Oct 05, 2011 6:45 pm  (#12)
GnuTux
I checked the user control panel,it says i have no attachements.
Don't know if i am (again) doing it wrong
PostPosted: Wed Oct 05, 2011 6:52 pm  (#13)
The attachment has to be attached to one of your posts for it to show up in your User Control Panel. Otherwise, it shows up in the Administrator's panel under "orphaned" attachments. I periodically delete "orphaned" attachments.
PostPosted: Wed Oct 05, 2011 6:55 pm  (#14)
ah ok
and thank you for your patience :
PostPosted: Wed Oct 05, 2011 7:02 pm  (#15)
No problem. When attaching a file, you need to..
1) Browse to the file 2) Click "add the file" (comment optional) 3) Submit the post.
Hope that helps.
PostPosted: Wed Oct 05, 2011 7:37 pm  (#16)
Hey Pirate thats Kewl, you worked hard at it and it finally paid off. good for you.
PostPosted: Wed Oct 05, 2011 7:43 pm  (#17)
Thank You Molly :)
I am actually learning patience which is never easy for an Italian :)
PostPosted: Wed Oct 05, 2011 9:01 pm  (#18)
Well done Pirate!!
PostPosted: Thu Oct 06, 2011 3:39 am  (#19)
S-W-E-E-T
PostPosted: Thu Oct 06, 2011 5:16 am  (#20)
Hello splashscreen...!
