It is currently Thu Nov 19, 2026 2:14 pm
 Post subject: Colored BBs mosaic.
PostPosted: Sun Oct 02, 2011 9:30 pm  (#1)
Just an excuse to have more fun with RobA's cool Mosaic Helper Script-fu. Got a little lazy with the coloring of the BBs. lol
This is a crop of my Dad. :)
 Post subject: Re: Colored BBs mosaic.
PostPosted: Mon Oct 03, 2011 3:49 am  (#2)
pretty darn cool Lyle.
PostPosted: Mon Oct 03, 2011 4:32 am  (#3)
That is far out! :)
PostPosted: Mon Oct 03, 2011 4:46 am  (#4)
yeah Rod, but he won't give us a tutorial on how he did it. :gaah
PostPosted: Mon Oct 03, 2011 9:55 am  (#5)
Yeah, Lyle. You're so mean to us teasing like that. Looks kinda like the lite-brite thingy you did before. :coolthup
PostPosted: Mon Oct 03, 2011 10:26 am  (#6)
Thanks for the responses. RobA created the Script-fu and he would know better then me how to get the most out of it, but anyway the following's my flow. I used RobA's Script-fu to create the paths. It's just a matter of stroking the paths after the Script-fu creates them. All I did was use G'MIC (could have just used Color>Threshold) B&W Stamp on my Dad's Portrait, went to Channels Dialogue and right-Clicked>Channel to Selection to select the Whites, ran RobA's Mosaic Helper Script-fu, Invert Selected, ran it again and merged all the paths. Deseleted (don't forget to do that; lol) and stroked with a ball bearing brush. I then went to Layers>Transparancies>Alpha to Selection, Inverted Selected, and ran RobA's Script-fu again to fill in the parts that the first two passes didn't. I stroked that path with the same ball bearing brush and merged all the layers. To colorize (again, I should have used the selection island script-fu, but wanted a quicker result, I took my Dad's portrait and copied it above the ball bearings, blurred the picture and added alpha channel (don't forget to do this) and duplicated for a total of three layers. I set the Top layer to color, the next layer to Saturation, and the third layer to Burn and lowered the Burn layer opacity to taste (usually 50% to 70%). Merged visible, duplicate, and on the lower layer ran motion blur (radius 5, 235degs) and then flattened with black canvas. That is the flow anyway. Way too many captures to do a tut though and you guys know how not a tut guy I am. lol
PostPosted: Mon Oct 03, 2011 10:59 am  (#7)
lol. that is cute. thanks Lyle, I know... (you are lazy)... at least you say you are. :teeth
PostPosted: Mon Oct 03, 2011 11:45 am  (#8)
Thanks for the comments Molly. :)
PostPosted: Mon Oct 03, 2011 11:49 am  (#9)
Really great, Lyle. :hehe
Lyle, did you post your bb brush somewhere? Is there a way we can have it?
PostPosted: Mon Oct 03, 2011 12:02 pm  (#10)
I may have before but it's been a little while and it may even have been at GIMPTalk. lol
Don't even remember where I got the original before extracting it to create the brush (way back in 2008; memory cells long died off. lol). Note that you need to play with both spacing and size before using it for stroking (I did a temporary spacing change of 90). :)
bearing.gih [39.21 KiB]
Downloaded 99 times
PostPosted: Mon Oct 03, 2011 12:41 pm  (#11)
thanks Lyle.
PostPosted: Mon Oct 03, 2011 12:49 pm  (#12)
:tyspin
