It is currently Thu Nov 19, 2026 3:00 pm
 Post subject: Gimp 2.7.3 first images for new GPS series.
PostPosted: Tue Oct 04, 2011 9:32 am  (#1)
Hi all, recently i have started to work in the new serie of GPS for 2.7 . so here you have the first images.
and a new Chalk preset that is really cool using tilt and new dynamics.
 Post subject: Re: Gimp 2.7.3 first images for new GPS series.
PostPosted: Tue Oct 04, 2011 9:36 am  (#2)
I'm delighted to see more stuff from you, Shock! I love the golden color in the surreal, landscape image and that chalk preset is great!
PostPosted: Tue Oct 04, 2011 9:41 am  (#3)
I love that chalk one
PostPosted: Tue Oct 04, 2011 10:28 am  (#4)
Perfectly !
Which version GIMP do you use?
Is this:
Gimp-Portable-2.73 GPS ?
http://www.graphicall.org/349
[Gimp 2.7.3 + Themes + GPS + GMiC (Partha)]
and perhaps other ?
PostPosted: Tue Oct 04, 2011 10:40 am  (#5)
Hy Ramon the image is great and i am happy that you start to port GPS preset and create new ones
i saw a bad news from Alexia about Gimp & graphic tablets on windows
Just a note on the windows build, tablets on windows wont work es extended devices. So no pressure. GTK2 versions required for 2.7.3 are all broken in this regard. Unless someone fixes GTK for Windows that's how it's going to go out at 2.8.
It was solved or you swhitched to linux ?
EDIT
i looked better the screenshot...i see you switched to Ubuntu
@ MareQ
that should answer to your question too.
Actually would be very bad (not only for Digital painters but also for Photo retouch, expecially of old damaged photos if gimp-2.8 for Windows would be without tablet support...but seems nobody is trying to fix it also because it seems not a Gimp but a GTK windows-only bug, ...i believe not a single GTK developer uses Windows and that is very bad for the hopes in a quick fix
PostPosted: Tue Oct 04, 2011 10:47 am  (#6)
Beautiful Shock...I love all your work.
PostPosted: Tue Oct 04, 2011 11:19 am  (#7)
So when does the new version hit the public?
I love those presets you come up with. :)
The new chalk one is really amazing.
PostPosted: Tue Oct 04, 2011 11:42 am  (#8)
Stunning work, Ramon!
PostPosted: Tue Oct 04, 2011 12:08 pm  (#9)
Most excellent :paint
Kudos!!
PostPosted: Tue Oct 04, 2011 1:26 pm  (#10)
Thank a lot for your kind replies. I am glad you like it. To answer some questions briefly.
OS: Ubuntu 11.04
Tablet: Intuos 4 S
Gimp 2.7.3 from graphicall.org not partha release.
I see a BIG problem in GTK win users, if gimp 2.8 arrives without pressure because then GImp will be useless for Painters. so rude so real. we already have problems with wacom and this is not good. we have to be "geeks" sometimes. weird :S
About public releases i am refining the presets amount i see they are too much. and i think lighter but well choosen presets would be better. i am on it so any advices or comments are more than welcome.
PostPosted: Tue Oct 04, 2011 3:32 pm  (#11)
Yes it will really be bad a so long expected new Gimp with broken support for tablets
The Gimp devs are already busy, and not directly responsable of GTK bug...put any more pression on them will be of not any good may only worsen
But maybe troght forum and blog we may find somebody ELSE knowing Windows and willing to found a patch for the GTK
(maybe who know even a call for help to wacom may help...even if we are just a niche in their market still we are client )
OOPPSS TheShock sorry for the almost OT , but that it is such huge obstacles for future projects
PostPosted: Mon Oct 17, 2011 12:39 pm  (#12)
GIMP Paint Shop by Ramon Miranda aka TheShock
http://code.google.com/p/gps-gimp-paint-studio/
This is important for those interested in detail:
http://www.graphics-muse.org/source/GPS.pdf
For GIMP 2.7 I found:
http://graphicall.org/349
It works beautifully (also for 2.7.4 PARTHA) - except the installation of Portable XP 32 bit.
Everything works - only MATHMAP suddenly gives an error (weird - what relationship ??? - but I checked on different computers)
Any suggestions?
ps.In addition to the theme - but with the need to: Please download mathmap for Linux 64-bit (Ubuntu) does not work links - if someone can share?
PostPosted: Mon Oct 17, 2011 12:42 pm  (#13)
I'm sorry! Strange, I see the error repeat post.
PostPosted: Mon Oct 17, 2011 1:13 pm  (#14)
@TheShock,
If you happen to use KDE as desktop: http://kde-apps.org/content/show.php?ac ... ent=114856
It contains install instructions.
It's working quite well for my Wacom PT tablet.
If you don't use KDE it probably won't work because it depends on KDE libraries.
Gerard.
Gimp-2.8.14
I use Linux only.
And Virtualbox with Win 7
PostPosted: Mon Oct 17, 2011 1:30 pm  (#15)
@gerard82
I use Gnome for my desktop,and for the moment is ok in gimp. I use KDE libraries for Krita betatesting but inside gnome.
PostPosted: Mon Oct 17, 2011 1:35 pm  (#16)
Then you might have the necessary libs.
By the way Gnome and KDE won't bite each other.
Gerard.
Gimp-2.8.14
I use Linux only.
PostPosted: Mon Oct 17, 2011 1:44 pm  (#17)
This is where you can set pressure etc.
Gerard.
Gimp-2.8.14
I use Linux only.
