It is currently Fri Nov 20, 2026 7:41 am
 Post subject: A strange all seeing eyeball..
PostPosted: Thu Jun 17, 2010 4:45 pm  (#1)
I may just make this my new splash screen =)
 Post subject: Re: A strange all seeing eyeball..
PostPosted: Thu Jun 17, 2010 9:08 pm  (#2)
Cool. Polar coordinates is how you get it round? do you use wind, also?
PostPosted: Thu Jun 24, 2010 12:23 am  (#3)
i used polar cord for the eyeball...the sort of lightening bolt effect is really the water drop effect , and the rays of light are created from this filter... Wills Script Pack (border glow). The text is mostly created by rerunning the curves filter
download it (wills script pack) here ... http://se2014.com/~wmorris/proj/will_gimp_scripts.tar
just make sure to place all the scm files in your scripts folder and make them all executable (unblock them)
PostPosted: Tue Jun 11, 2013 6:33 am  (#4)
Hi G,
I downloaded and tested them. Both work as intended.
The 'Border' one must be run on a layer with an Alpha Channel and also a selection.
Let me know what issues you are experiencing :)
PostPosted: Tue Jun 11, 2013 6:35 am  (#5)
Excellent image Rod.
PostPosted: Wed Jun 12, 2013 9:20 am  (#6)
Excellent results Rod.
PostPosted: Wed Jun 12, 2013 10:23 am  (#7)
Very cool.
PostPosted: Wed Jun 12, 2013 5:54 pm  (#8)
Flashback to the Twilight Zone.
PostPosted: Wed Jun 12, 2013 6:04 pm  (#9)
:lol this is a very old post by the way. Some scripts probably will need to be updated for this tutorial.
PostPosted: Wed Jun 12, 2013 9:52 pm  (#10)
Twilight zone is also very old, timeless in fact.
PostPosted: Thu Jun 13, 2013 1:22 am  (#11)
It sure is. :)
I love that show and "The Darkside". Remember "Circle of Fear" :bigthup
