It is currently Thu Nov 19, 2026 3:00 pm
 Post subject: Some Rodilius Magic
PostPosted: Wed Oct 05, 2011 7:25 am  (#1)
Original
After the magic (GIF low quality)
PNG (high quality)
Seems Rodilius is also good at capturing details from shadows. :bigthup
 Post subject: Re: Some Rodilius Magic
PostPosted: Wed Oct 05, 2011 8:06 am  (#2)
Does it make the coffee too ?
:coolguy
PostPosted: Wed Oct 05, 2011 8:07 am  (#3)
I need some! :)
Coffee that is.
PostPosted: Wed Oct 05, 2011 8:32 am  (#4)
That's a pretty good discovery, Rod. Quite useful. :tyspin :zzz :mcof
PostPosted: Wed Oct 05, 2011 9:33 am  (#5)
To get the effect -
Open your image
Duplicate it
Run Rodilius with these settings
Now duplicate that layer place it on top,and set the mode to divide.
Set the Rodilius layer under it to soft light.
The original should be at the bottom.
Now play with the soft-light mode layers opacity settings to get the effect.
Incidentally just having the first top Rodilius layer in divide mode produces some interesting cartoon type effects. ;)
PostPosted: Wed Oct 05, 2011 10:45 am  (#6)
Perfect! Just what I needed to figure out how to do it. Thanks for posting the explaination for everyone.
PostPosted: Wed Oct 05, 2011 10:56 am  (#7)
I see what you mean by the cartoony effect. Nice work Rod.
File comment: this is the original
