It is currently Thu Nov 19, 2026 3:00 pm
 Post subject: Haloween
PostPosted: Thu Oct 06, 2011 8:43 am  (#1)
Getting ready for halloween:D
 Post subject: Re: Haloween
PostPosted: Thu Oct 06, 2011 2:17 pm  (#2)
Did a search.
viewtopic.php?p=14178#p14178
PostPosted: Thu Oct 06, 2011 8:11 pm  (#3)
how in the world do you add audio to a graphic?
PostPosted: Thu Oct 06, 2011 11:53 pm  (#4)
Nice! The background is so cool!
PostPosted: Fri Oct 07, 2011 1:35 am  (#5)
Please do Rod I done how it's done. Adding the audio with it will be more effective. O I had a look at yours, yours looks brill
PostPosted: Fri Oct 07, 2011 3:57 am  (#6)
Thank you! Yours is every bit as nice. You amaze me at how fast you learn.
PostPosted: Fri Oct 07, 2011 4:55 am  (#7)
Once I put my mind into it I get right stuck into it. The easist way to learn, is to jump in the deep end and that's want I do. I learnt that when I started caring the elderly many years ago.
PostPosted: Wed Oct 12, 2011 8:07 am  (#8)
...Stand beside it with a tape recorder containing stock lightning sound effects, and mash the play key with perfect timing?
PostPosted: Wed Oct 12, 2011 11:20 am  (#9)
You have to convert it to Flash first.
Audio on the forums is kind of frowned upon though with great understanding. ;)
It can be very distracting to other users.
PostPosted: Wed Oct 12, 2011 12:54 pm  (#10)
You asked so nicely i couldn't resist. :)
http://simply-signage.com/swf/halloweenlorri.html
swf Video format : swf
 Post subject: Re: Halloween
PostPosted: Wed Oct 12, 2011 2:10 pm  (#11)
Rod that is absolutely brilliant I love it. I like to know how you did it?
PostPosted: Wed Oct 12, 2011 2:15 pm  (#12)
That is very cool Rod...we will call you the sound effect man.
PostPosted: Wed Oct 12, 2011 2:17 pm  (#13)
Hey Molly! we have to get Rod to do all our sound tracks for us to our animations
PostPosted: Wed Oct 12, 2011 2:43 pm  (#14)
Glad you like it.
You have to have a SWF editor to do it.
Then just open the GIF as frames and add each sound file to certain frames.
The buttons need to have 3 separate actions
over - hover action such as color change
down - what does the movie do when the button is pressed down (such as go to a frame and play it or play a sound file embedded in the SWF actionscript.
release/hit - color of button after hitting or activation.
That is how action script understands and reads buttons.
On a side note i do not mind adding sound for you guys to your GIF files. :)
