It is currently Thu Nov 19, 2026 3:04 pm
 Post subject: Creative Transparency (Tutorial & Material)
PostPosted: Sat Oct 08, 2011 12:36 am  (#1)
This is a Tutorial and do not require any previous knowledge of gimp
you may wonder why to post a Tutorial in the Art Board
This tutorial doesn't need to be written only performanced, .it is a game about creativity
we may start now, so load gimp and be ready for the fun
MATERIAL
As shameless plug we may use my new semitransparent patterns ....
Semi Transparent Patterns (Hi Trans) by PhotoComix_Mandala, on Flickr
Semitransparent pattewrn by PhotoComix_Mandala, on Flickr
i have much more here http://www.flickr.com/photos/photocomix_mandala/
THE GAME Phase 1
To play you must open your gimp, open the first pattern as image (Be sure to not loose tranparency .often Windows strip away transparecy when drag and drop,..in case instead then D & D save you should save and open) then open a few others using FIle/Open as layer.
You should immediatly see the magic !
Now find the best combination(s) may be the most intricated , or the most rich of depth or more decorative
Once you get copy the visible/paste as new Image and upload here
The game (and the tutorial because this Game is a Tutorial )will become more and more complex
So PLEASE don't add ANY complication here stick to the few and simple rules
RULES
YOU MAY
Use as many layers you want
toggle layer visibility on/off
add copy of the visible
add a SOLID color BG
YOU MAY NOT
NO merging modes, ONLY accepted mode is the default (Normal at full opacity )
NO Offset...offser will be in Phase 2 or 3 here
NO brushing or erasing, no Filters or similar
Just load the pattern , play with their postion in the stack
raise ,lower (CTRL+ L open layer window) ,toggle on off the eye icon just do NOT offset
[/align]
 Post subject: Re: Creative Transparency (Tutorial & Material)
PostPosted: Sat Oct 08, 2011 1:06 am  (#2)
The full set is here http://www.flickr.com/photos/photocomix ... 836690722/ ,about 50n in the set
PostPosted: Wed Oct 12, 2011 10:15 am  (#3)
Just in case somebody wonder what this was about...i was try to explain how to create complex animation as here
swf Video format : swf
more on
viewtopic.php?f=11&t=2797
And the very first step is find 3 or 4 semitransparent pattern that combine well togheter...then step 2 is to animate each single pattern...
PostPosted: Wed Oct 12, 2011 10:34 am  (#4)
Nice PC! :)
PostPosted: Wed Oct 12, 2011 10:46 am  (#5)
I used only BW as proof of concept, to simplify
but of course the same may be done with semitransparent COLORED patterns
And the wheels are only 1 of possible effects
PostPosted: Wed Oct 12, 2011 11:05 am  (#6)
Something like this with gears would be pretty outstanding looking also. :)
Pretty mesmerizing.
