It is currently Thu Nov 19, 2026 3:02 pm
 Post subject: hypno wheels spin again
PostPosted: Tue Oct 11, 2011 4:09 pm  (#1)
sorry the link for the video doesn't work !! :gaah
 Post subject: Re: hypno wheels spin againg
PostPosted: Tue Oct 11, 2011 4:39 pm  (#2)
:gaah file is a bit more of 5MB and is swf, doesn't seems easy find a host
OK but is only for download i can't hotlink, FF and even IE should display well
http://www.box.net/shared/ra866hq3nfiytopsmlxp
PostPosted: Tue Oct 11, 2011 5:26 pm  (#3)
Wow! Excedrine headache #27.
Either that or Huie Lewis has to change his lyrics from "I wanna new drug" to "I wanna new script".
Awesome PC!
PostPosted: Tue Oct 11, 2011 6:47 pm  (#4)
Me too Drac,
My eyes are still blurry and I can see black and white and yellow and red spots. Very good PC.
PostPosted: Tue Oct 11, 2011 7:15 pm  (#5)
Here ya go, PhotoComix.
swf Video format : swf
Instant headache, for sure.
PostPosted: Tue Oct 11, 2011 9:02 pm  (#6)
so that is what LSD is all about!!!!
PostPosted: Tue Oct 11, 2011 9:38 pm  (#7)
awesome!
PostPosted: Tue Oct 11, 2011 10:03 pm  (#8)
That is really cool PC! :)
Did you create that?
PostPosted: Wed Oct 12, 2011 5:09 am  (#9)
yes i was even thinking to create a sort of tutorial viewtopic.php?f=11&t=2766 but then i didn't saw much interest so i just posted a end result
anyway the idea is use 2 or 3 pattern of the same size with large transparent area as
each pattern is open as image
for create the animation i used mathmap (distort /enhanced pond ) here a possible result
now just do the same for the other pattern, again each pattern is on its own image
Now use gap
1) image to frames
close the original remain with only the first frame of the image open
2 )move path, use move path to assemble the layers
3) now each frame should have 2 layers , to check if everything is fine you may use Video/playback
If fine do Frames to image to reassamble everything in a single image
then gmic /Array/Mirrored array,
Disable the gmic preview(will slow down too much ) set Input to ALL output to NEW IMAGE mirror XY, check expand...
PostPosted: Wed Oct 12, 2011 5:18 am  (#10)
Wow..this is amazing PC.I'm really hypnotized.
My Flickr
PostPosted: Wed Oct 12, 2011 6:37 am  (#11)
HELP !
that was just a wip i have a better one but i can't find a hosting side (or they say is too big or that is not a swf or.. :gaah )
I may upload to boxnet but my free account only allow to give the link for the download page
http://www.box.net/shared/r9r7o3ok4hntngp7jp94
PostPosted: Wed Oct 12, 2011 7:22 am  (#12)
Got it fixed up there for you, PhotoComix. Very cool vid.
PostPosted: Wed Oct 12, 2011 7:26 am  (#13)
thank a lot O !
PostPosted: Wed Oct 12, 2011 9:14 am  (#14)
Ooppss the last is too big even for box.net so i ended up with megaupload.com that let wait 30 sec for free download..uff )
BTW i was already planning a tut, only problem is that as soon i start the screen- videorecorder, gimp start to ignore mouse command (i click and nothing happens )
Ok upload is finished, ...hem O could you do again the miracle ? :geek
http://www.megaupload.com/?d=H5KR2JR4
PostPosted: Wed Oct 12, 2011 9:49 am  (#15)
Your LAST file didn't have an extension so I made it LAST.swf to appease the computer gods. :hexer
PostPosted: Wed Oct 12, 2011 10:00 am  (#16)
...Oppss Thank O
PostPosted: Wed Oct 12, 2011 10:54 am  (#17)
PC those are fantastic! :)
