It is currently Thu Nov 19, 2026 2:06 pm
 Post subject: Rodilios with Lions ,Old Woman , and other victims
PostPosted: Wed Oct 19, 2011 8:18 am  (#1)
A mix of Rhodilius and Wild Cartoonizer
Beautiful Old Woman ORIGINAL
Beautiful old lady from Darap(Sikkim) village by Sukanto Debnath, on Flickr
Wild Cartoonizer plus Rodilius (option Darken )
[G'MIC] Rodilius ; -gimp_rodilius 6.23656,10,178.571,17,30,0,0,0 by PhotoComiX, on Flickr
a step before ONLY WIld Cartoonizer
[G'MIC] Local normalization ; -gimp_normalize_local 3.25301,7,2.16867,20,1,3,0#1 by PhotoComiX, on Flickr
Same After Rodilius ( with standard lighen option ) and Local Normalization
Visible#7 by PhotoComiX, on Flickr
More Rodilious variation
Visible#6 by PhotoComiX, on Flickr
Visible#5 by PhotoComiX, on Flickr
Just Wilde Cartoonize with Painter Touch Modulo enabled
Visible#9 by PhotoComiX, on Flickr
If you dislike the Wild Cartoonizer wild color shift you may correct with BN
SAME as above + BN Dithering
[G'MIC] B&W dithering ; -gimp_ditheredbw 1,1,0,0,0#1 by PhotoComiX, on Flickr
Same effect faded down
Visible#10 by PhotoComiX, on Flickr
OK the last 2 were a bit off topic so now back in topic with Rodilious Lions
(comining soon)
 Post subject: Re: Rhodilous with Lions ,Old Woman , and other victims
PostPosted: Wed Oct 19, 2011 8:21 am  (#2)
The third one looks like a church stained window
PostPosted: Wed Oct 19, 2011 8:28 am  (#3)
OOPPSS i forgot to upload the lions...doing now in the while a last Rodilious (plus Swiss Mask )
[G'MIC] Contrast swiss mask ; -gimp_contrast_swm 2,0,1 by PhotoComiX, on Flickr
 Post subject: Re: Rodilios with Lions ,Old Woman , and other victims
PostPosted: Wed Oct 19, 2011 10:20 am  (#4)
Wow, PhotoComix, all of them are outstanding. I particularly like the black and white one and the "stained glass look" ones.
PostPosted: Wed Oct 19, 2011 10:55 am  (#5)
Oregonian glad you like :jumpclap
i never used Rodilious much but now i think i found how to misuse
Lions take ages to upload maybe flickr has hiccup, and i know other ages to add the credit under the photo
But anyway the Lions are coming so be aware !! :wh
PostPosted: Wed Oct 19, 2011 10:57 am  (#6)
Like O, I like the stained glass one too PC. :)
PostPosted: Wed Oct 19, 2011 1:00 pm  (#7)
PC you may have stumbled upon how Redfield gets that glow look.Maybe you can spread the news to David? :)
With your smoothing techniques and Rodilius combined that may just be the ticket.
Particularly (Contrast Swiss Mask).... make that Graphic Boost.
So far i have only been able to mimic it by adding a top layer in burn mode.And that really doesn't get it quite right either.This looks promising though.
PostPosted: Wed Oct 19, 2011 1:15 pm  (#8)
David alreadu know about Local Normalization but yes also Swiss Mask may do the trick and somehow more softly.
I Lions are ready...
PostPosted: Wed Oct 19, 2011 1:35 pm  (#9)
Here it is (Rodilius), with GB with pencil smoothing enabled.
I ran Graphic Boost first then Rodilius (default settings).
I had to add a few different layers for effect modes also.
Plus some gradient transparencies.
This is close to what i am looking for though. :)
PostPosted: Wed Oct 19, 2011 2:23 pm  (#10)
Nice effect on the dog !
here the original Lions
and i start with a very rough draft.. (Rodilius option for darken)
Rhodilious by PhotoComiX, on Flickr
Rough but the secret is to never overwrite layers, only add new and this layer will be perfect to make the Lions more mean
See now merged back..sure .colors look a bit washed out
TGmic- tested on Lions by PhotoComiX, on Flickr
but is easy correct the color
Or with muted colours
Ahh but maybe you want to see the Fractalious -like Rodilious that with white lines...
something as this...oh well this has too low contrasy and saturation and no depth
... but is good to start
The same with contrast and saturation pushed (by duplicate layer on top in multiply mode )
But i prefer a bit more realistic effect as from ghostly or demozized Lions
Or maybe a bit more soft effect ?
again saturation and contrast may be changed easily
as
or
but if you like more extrem..here you are
LAST EXPERIMENT (erode is one of the gmic morphological operation )
PostPosted: Wed Oct 19, 2011 2:27 pm  (#11)
The realistic is pretty good PC
PostPosted: Wed Oct 19, 2011 3:47 pm  (#12)
I like them all. :)
Nice addition to GMIC PC!
Thanks.
