It is currently Thu Nov 19, 2026 2:08 pm
 Post subject: Draft, Sketch, Cartoonize, ....
PostPosted: Sun Oct 23, 2011 8:51 am  (#1)
our model
The Grateful Undead by Jan Tik, on Flickr
A Graphic Boost preset
[G'MIC] ;GB; color mood ; -gimp_graphic_boost3 1.62602,0.894309,0,0.552846,29.2683,0,1,0.731707,0.894309,4.06504,0,1,5,1,1,0.5,0.756098,1 by PhotoComiX, on Flickr
Sketch with Rodilious (Color option = Darker)
[G'MIC] Rodilius ; -gimp_rodilius 8.57143,4.7619,246.032,21,30,0,0,0#1 by PhotoComiX, on Flickr
[G'MIC] Contrast swiss mask ; -gimp_contrast_swm 2.90361,0,1#1 by PhotoComiX, on Flickr
Same + SwissMask (boost option)
[G'MIC] Rodilius ; -gimp_rodilius 10.4762,11.1111,246.032,21,30,0,0,0 by PhotoComiX, on Flickr
Combining as layers the last 3
Visible#2 by PhotoComiX, on Flickr
Another Mix (Graphic boost+ Rodilius)
Visible#1 by PhotoComiX, on Flickr
RODILIUS + WILD CARTOONIZER
sharp
[G'MIC] Quick Cartoonizer-screenhard ; -gimp_m_l_unsharp2 56.8627,3.85621,1.96078,3.20261,75.1634,71.2288,0,0.464,0.72,3.28,3 by PhotoComiX, on Flickr
soft
[G'MIC] Quick Cartoonizer-grainy ; -gimp_m_l_unsharp2 14.794,3.84,0.749064,2.88,58.9888,37.396,1,0.40824,0.659176,3.40824,0 by PhotoComiX, on Flickr
softer
[G'MIC] Quick Cartoonizer-screenhard ; -gimp_m_l_unsharp2 56.8627,3.85621,1.96078,3.20261,75.1634,71.2288,1,0.464,0.72,3.28,3 by PhotoComiX, on Flickr
GRAPHIC BOOST+ RODILIUS+ GRAPHIC BOOST
[G'MIC] ;GB;-circlism -2 ; -gimp_graphic_boost3 2.18182,0.06,0,0.187654,120.988,0,1,0.781818,0.894309,4.06504,0,1,3,0.676543,1,0.571429,0.333333,1 by PhotoComiX, on Flickr
 Post subject: Re: Draft, Sketch, Cartoonize, ....
PostPosted: Sun Oct 23, 2011 10:24 am  (#2)
Love those results PC!
PostPosted: Sun Oct 23, 2011 10:33 am  (#3)
I feared that the Model was not sufficently hairy so ...
[G'MIC] Local normalization ; -gimp_normalize_local 8.6747,11,5,20,1,3,0#1 by PhotoComiX, on Flickr
That BTW is Rodilius + Local normalization...very good combination
PostPosted: Sun Oct 23, 2011 10:54 am  (#4)
:clap :hi5 Those are all great. Your hairy one made me grin. :mrgreen:
PostPosted: Sun Oct 23, 2011 2:14 pm  (#5)
Original
with the same soft Graphic Novel preset
as 2 but GN used once more
a draft from tiis last With Rodilus
darker draft
a ghostly Rodilius
and the ghostly Rodilius after Wild Cartoonizer...
PostPosted: Sun Oct 23, 2011 11:43 pm  (#6)
My favs are ghostly in the above set and Rodilious (Color option = Darker) in the first set.
PostPosted: Mon Oct 24, 2011 2:41 am  (#7)
great effects!
