It is currently Thu Nov 19, 2026 2:59 pm
 Post subject: Just playing with gradients
PostPosted: Sat Oct 29, 2011 6:55 am  (#1)
Just playing with some of the gimp gradients:
My Flickr
 Post subject: Re: Just playing with gradients
PostPosted: Sat Oct 29, 2011 8:04 am  (#2)
Hi - I think you're my soul mate
because is also my favorite game.
I recommend the program to the gradients Create Gradient from Image application 1.0.0.7
http://registry.gimp.org/node/25571
PostPosted: Sat Oct 29, 2011 8:37 am  (#3)
Thanks MareroQ for this tip,but i'm little confused...don't know what file do i need to download?Is it Change image 7.zip file.?
My Flickr
PostPosted: Sat Oct 29, 2011 9:05 am  (#4)
You have to unpack and optionally add a shortcut to the location.
This is an independent development program - but it will also (ever?) as a GIMP plugin (after testing).
Author - MalyszKZ - promise of development...
PostPosted: Sat Oct 29, 2011 9:12 am  (#5)
Ok thanks......i'll try...hope i can make it:)
My Flickr
PostPosted: Sat Oct 29, 2011 9:53 am  (#6)
looks wonderfully beautiful Ana. Believe PC also is a guru of gradient blending. :)
PostPosted: Sat Oct 29, 2011 10:00 am  (#7)
Thank you Lylejk :).
My Flickr
PostPosted: Tue Nov 01, 2011 6:20 am  (#8)
Hi Ana,
Do you already use the program GradientFromImage?
Really worth it to install - quick examples of the use is attached (implementation of specific sleep).
On how many layers you create an image ?
Besides the beautiful composition (congratulations) - something to think (from what I associate it?).
Your works are beautiful - why no name ?.
The problem with the choice of names:
proposes a trade:
name my paintings with gradients - and I in return Your ...
PostPosted: Tue Nov 01, 2011 7:07 am  (#9)
MareroQ wrote:
Hi Ana,
proposes a trade:
Hi MareroQ...I download it but don't know how to install....do i need only this exe file to put in gimp plugin folder ?
As for names, sometimes I have no idea...i get stuck with that.
My Flickr
PostPosted: Tue Nov 01, 2011 11:16 am  (#10)
Ana wrote:
MareroQ wrote:
Hi Ana,
proposes a trade:
Ana,
Just extract it to a folder named ChangeImage on your C drive (i.e. C:\ChangeImage)
Once you have extracted it and open that folder that you named ChangeImage you'll see a folder named 'Standard Graphics File' and an executable 'ChangeImage.exe' All you need to do is double click on ChangeImage.exe (the application) and the program will start. It's a stand alone application.
Note: Once you have started it, click on the splash screen else you'll be there forever!
Hope this works for you! If not PM me.
PostPosted: Tue Nov 01, 2011 11:47 am  (#11)
Ana, it will look like this after you extract it. I have it on my desktop, just double click it and as MrBiggz says, click the splash screen. Open it in full in order to see the options at the top.
PostPosted: Tue Nov 01, 2011 12:15 pm  (#12)
Thank you Molly and MrBiggz....just to make sure....all i need to extract is this
right???
My Flickr
PostPosted: Tue Nov 01, 2011 12:32 pm  (#13)
yes, that is the exe file. it is already extracted
PostPosted: Tue Nov 01, 2011 12:35 pm  (#14)
OK Molly...i extract it direct to my desktop.I didn't create any Folder/file in my C disc.Can i leave it like that or do i need to create that folder??
My Flickr
PostPosted: Tue Nov 01, 2011 1:07 pm  (#15)
You can but I just have it on the desktop as an exe file, you just need to double click it and the splash screen comes up and thats it. It is a very small program, It isn't in English but you just open your file the same way you would in gimp, open an image and make a gradient out of it. It will save as a gradient and then just put it in your gradient folder.
I really haven't done much else with it yet so maybe there is more in there I haven't seen yet.
PostPosted: Tue Nov 01, 2011 1:21 pm  (#16)
Thank you Molly.
My Flickr
PostPosted: Tue Nov 01, 2011 2:26 pm  (#17)
OK...here it is..my first try with this program......
This is the original photo
and this is the gradient i made (brownish gradient) with linear shape
with spiral shape
then i change the gradient mode to difference and made this
and this is after i run Darla's Amazing circle script
so...what you think??
My Flickr
PostPosted: Tue Nov 01, 2011 2:36 pm  (#18)
Very cool Ana. It will be handy when you want to match up a background with what you are working on. I have done that and works well. good work.
PostPosted: Tue Nov 01, 2011 2:56 pm  (#19)
Thanks Molly.Now i can see that this program is going to be very usefull.Love it already :) :jumpclap .
My Flickr
PostPosted: Tue Nov 01, 2011 4:41 pm  (#20)
Yes it is nice and small, you don't even have to install it. :gaah :teeth
