It is currently Thu Nov 19, 2026 3:00 pm
 Post subject: 3D Circle
PostPosted: Sun Oct 30, 2011 6:57 am  (#1)
My Flickr
 Post subject: Re: 3D Circle
PostPosted: Sun Oct 30, 2011 7:50 am  (#2)
fascinating and beautiful...so how did you do this?
PostPosted: Sun Oct 30, 2011 7:56 am  (#3)
cool Ana
PostPosted: Sun Oct 30, 2011 8:05 am  (#4)
I would like to know also 2-ton.I must loosing my mind.I'm trying to figure it out on another gradient example but i'm stuck.i know i used mathmap (kaleidoscope filter)and Darla's script for the Amazing circle but the rest :( :gaah
Sorry for this.I think that i need to write every step that i make in gimp .
I've got it.Yipiiii.
Create new white layer.Choose one of these gradients Horizon 1 ; Horizon 2 ; Land 1 ;Nauseating Headache (i think i used horizon 2).Then I set the mode of the gradient to difference and the shape to radial.
Now from each of the four corners create gradient (from the top left corner to the bottom right corner ; from the bottom right corner to the top left corner ; from the top right corner to the bottom left and from the bottom left one to the top right corner).Next….you need four more gradients,one from each corner to the middle of the image.
It's time for Darla's Amazing circle script (used default settings),then i make white background invisible.Mark the circle and run Mathmap (kaleidoscope filter).After that i add mat and frame.Finally i make white background visible.
Hope this was understandable.
My Flickr
PostPosted: Sun Oct 30, 2011 8:06 am  (#5)
cool Ana
Thanks Molly.
My Flickr
PostPosted: Mon Oct 31, 2011 5:38 am  (#6)
Here is another one....i know it's not like the first one :( think i need more practice....hope you like this one too :)
My Flickr
PostPosted: Mon Oct 31, 2011 11:47 am  (#7)
Oh hang on diving in the first one :D That so real, really out towards you.
They are cool Ana
PostPosted: Mon Oct 31, 2011 3:28 pm  (#8)
They are cool Ana
Thanks Lorri. :)
My Flickr
PostPosted: Mon Oct 31, 2011 3:44 pm  (#9)
Former Member
I love how glossy it is, but don't understand why it has a border?
PostPosted: Tue Nov 01, 2011 7:26 am  (#10)
hei, can I use your circle in post #6 for some photomanipulation (the one which looks like green lotus)? of course I will link back here. thanx in advance
PostPosted: Tue Nov 01, 2011 7:35 am  (#11)
Yes,you can and of course...i'd like to see what you've done.
My Flickr
PostPosted: Tue Nov 01, 2011 12:19 pm  (#12)
Thanx. I will write link here if I finished. Btw, just curious, do you have account in deviantart?
PostPosted: Tue Nov 01, 2011 12:25 pm  (#13)
Yap..yes
My Flickr
PostPosted: Thu Nov 03, 2011 6:17 am  (#14)
May I know the name of your account in deviantart? And do you display the lotus in post #6 there? If yes, I want to fave it :-D.
PostPosted: Thu Nov 03, 2011 7:01 am  (#15)
Hanciong, You can download the lotus by right clicking on the image and save image to your desktop.
PostPosted: Thu Nov 03, 2011 1:11 pm  (#16)
Hi Hanciong.I didn't post it there....Only have maybe 10 images there.
Here is the link
My Flickr
