It is currently Thu Nov 19, 2026 3:00 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
 Post subject: Text Art with a Different Approach
PostPosted: Sun Nov 13, 2011 4:23 am  (#1)
Light bulb came on and I decided to give it a shot:
 Post subject: Re: Text Art with a Different Approach
PostPosted: Sun Nov 13, 2011 4:34 am  (#2)
This is what I have been wanting to do. very nice Mahv.
PostPosted: Sun Nov 13, 2011 4:47 am  (#3)
Well, it's quite easy to do now, Molly. I used GIMPressionist. I made a text brush (white text on black background 128 x 128 px)with different words in different angles/positions (extension .pgm is used, not .gbr or .gih) and placed it in .gimp-2.6/GIMPressionist/Brushes folder. If the folder doesn't exist you need to create it.
Select your image, and duplicate it. Change layer mode on top layer to Overlay. Run GIMPressionist on the bottom layer. If your image is in color, fret not, you can desaturate afterwards.
Select the text brush, and update the Preview. Switch to the size tab and raise the minimum/maximum sizes to suit. Reset the Preview before re-applying the new size parameters.
Once you're happy with the text size after running GIMPressionist. You'll need to readjust the top layer mode to Hard Light, then run the bottom Layer through PC's Dragan Tom Keil's PhotoIllustration filter in Artistic.
Ignore the mouse cursor in the bottom picture.
PostPosted: Sun Nov 13, 2011 4:55 am  (#4)
Thank you Mahv, I got that copied and will try it out later in the day. I have always liked that look.
I saw a video tutorial a while back and now I can't find it. It was quite long so I didn't get to write it out.
The author changed the face of a man, (he used his own face) into the bark from a tree. It was an amazing transformation.
PostPosted: Sun Nov 13, 2011 6:19 am  (#5)
Wow Mahvin. That's an awsome looking effect.
PostPosted: Sun Nov 13, 2011 6:40 am  (#6)
I got a tutorial up on my blog at http://www.mahvin.com/?p=2440.
Here's a video, too:
PostPosted: Sun Nov 13, 2011 6:48 am  (#7)
I'll have to have a crack at that...it looks great!!
PostPosted: Sun Nov 13, 2011 7:01 am  (#8)
excellent tute Mahv
PostPosted: Sun Nov 13, 2011 8:15 am  (#9)
Wow, mahv, that is wonderful. Going to have to give that a try. :hehe
PostPosted: Sun Nov 13, 2011 12:07 pm  (#10)
That is very cool! Is that your baby?
PostPosted: Sun Nov 13, 2011 1:38 pm  (#11)
Mahvin that is really excellent
Gimpimpressionist filter will really deserve some update is a great filter but really need a better preview ( a make it much bigger ass you may see if you use Partha 2,7 build, but the point is not only the size, would be better be able to pan and to zoom ) and way to save presets
looking now to your tutorial
PostPosted: Sun Nov 13, 2011 3:49 pm  (#12)
That is my cousin Aubree. She joined us back in September.
Did you figure out that a text brush is just a black background with white text? The only thing different is that GIMPressionist works with .pgm files.
PostPosted: Sun Nov 13, 2011 4:44 pm  (#13)
Aubree had that .. geez I'm try'n sleep look!
And yes! Once again .. dummy me should have watched the video before typing! :oops:
PostPosted: Sun Nov 13, 2011 6:02 pm  (#14)
I redid mine and I still left the color without desaturate. I erased the text out of the eyes also . I also change it to flowing instead of the default in the size.
I love this gimpressionist...first time I have used it. Thanks Mahv
PostPosted: Sun Nov 13, 2011 6:06 pm  (#15)
Looks fabulous! Good job, Molly!
PostPosted: Sun Nov 13, 2011 6:16 pm  (#16)
I was just looking at yours again and I can't get my text to cover where the highlights are on the face. I did 5 already and they are all like that. Yours covers the whole face.
PostPosted: Sun Nov 13, 2011 6:17 pm  (#17)
Got the picture here: http://www.photosofpictures.com/wp-cont ... es-102.jpg
PostPosted: Sun Nov 13, 2011 6:18 pm  (#18)
That is soooo awesome!
PostPosted: Sun Nov 13, 2011 6:21 pm  (#19)
sweeeet "O". This is baby day at the Gimp Ranch.
Your turn 2-ton.
PostPosted: Sun Nov 13, 2011 6:31 pm  (#20)
Result looks cool Mahvin. Could you share the pgm file if not the GIMPressionist preset itself? :)
