It is currently Thu Nov 19, 2026 4:07 pm
 Post subject: African Night Magic
PostPosted: Sun Nov 20, 2011 11:52 am  (#1)
Not yet on flickr, took hours to renders but i am very happy with it i hope you may see at large size
 Post subject: Re: African Night Magic
PostPosted: Sun Nov 20, 2011 12:03 pm  (#2)
That is fabulous. New art style.
We should call you PhotoImpressionist. Absolutely beautiful. It's certainly worth the hours it took. :yes :hi5
PostPosted: Sun Nov 20, 2011 12:05 pm  (#3)
I love that one PC, I like the bubbly sky especially.
PostPosted: Sun Nov 20, 2011 12:17 pm  (#4)
Looks great. :coolthup
Would especially look good large and from afar.
PostPosted: Sun Nov 20, 2011 12:32 pm  (#5)
Now there is a picture worth a lot of $$$ as opposed to the ones in this thread: viewtopic.php?f=15&t=3070
PostPosted: Sun Nov 20, 2011 1:15 pm  (#6)
@Molly ,Oregonian, Partha
thank for the comment and glad you like the style...Photoimpressionist sound nice
It was Lylejk to give the start with his works on Circlism, i love the circles but not their much solid color bg (now the filter allow transparent bg :yes ) i like more use variant of the original as BG
i am waiting for another "circlism" to render, in the while i want show another on the same theme , African Night Magic but a very different style.
well i was thinking to try to merge the 2 styles but seems a long wait (apply circlism on 2 layers may take so long...i believe another 2 hours :gaah ) so here a first version
IF YOU LOOK TO THE MAGIC; THE MAGIC MAY LOOK IN YOU
PostPosted: Sun Nov 20, 2011 1:33 pm  (#7)
I like that one too. The first thing I see are those luminous eyes! Beautiful.
PostPosted: Sun Nov 20, 2011 5:20 pm  (#8)
I like that one PC; I know you said African, but it almost looks Aboriginal to me and I do like Australian Aboriginal artwork. :)
PostPosted: Sun Nov 20, 2011 5:48 pm  (#9)
Yes I see what you mean about the eyes "O", they draw you right in. very nice PC
PostPosted: Sun Nov 20, 2011 7:58 pm  (#10)
Finito! ... :yes yes it works as i hoped!! :flirt :spring
PostPosted: Sun Nov 20, 2011 8:01 pm  (#11)
That came out really really good!
PostPosted: Sun Nov 20, 2011 8:59 pm  (#12)
Africangirlbubbles by PhotoComiX, on Flickr
PostPosted: Sun Nov 20, 2011 9:10 pm  (#13)
And last a homepage to the original Lylejk Circliosm style (but still you may see the eyes..maybe even the lips
circles with eyes by PhotoComiX, on Flickr
PostPosted: Sun Nov 20, 2011 10:08 pm  (#14)
PhotoComix wrote:
[align=center]And last a homepage to the original Lylejk Circliosm style (but still you may see the eyes..maybe even the lips
Last ? :hoh Who said was the last ?
Maybe you suffer sea sickness, or epilexy ? You don't know ?
I may offer a free test ...Look carefully here...
If you perceive any spinning try to let it flow...whirl...unwhirl...
girl-bubbles-distort1 by PhotoComiX, on Flickr
girl-bubble-distort2 by PhotoComiX, on Flickr
PostPosted: Sun Nov 20, 2011 10:27 pm  (#15)
I love the first and the last of the first page but i can't stop without one moree for Lylejk
PostPosted: Sun Nov 20, 2011 10:54 pm  (#16)
Circlism get's addicting eh PC. lol
Just wish it could be coaxed to be faster. Oh well; can't really afford a faster PC right now. :)
PostPosted: Mon Nov 21, 2011 11:12 am  (#17)
OOOPSS I FORGOT THE CREDIT
ORIGINAL AND CREDIT
most of original used are from Babasteve on flickr (he has a amazing gallery) click on the thumb to go on the image page
As you may see a secret for a good manip is start from excellent photo..
South Sudan 005 by babasteve, on Flickr
1020 Bhutan by babasteve, on Flickr
Istanbul 003 by babasteve, on Flickr
002 Madagascar by babasteve, on Flickr
PostPosted: Wed Nov 23, 2011 5:30 am  (#18)
MAKING OF "Back To The Magic" that is
Rod asked how i did
first the BG layer was this
BG
child1 by PhotoComiX, on Flickr
The BG layer contribute mostly for the eyes (visible trough layer masks on the other layers)
The BG layer was obtained by merging the original with a Graphic Novel variant in difference mode, dup the result and (since it was really light ) multiply on itself a couple of times
Then i created the layer that contribute for the final colors:
1 Step
Gmic/Artistic/Mescalito colors (also "Colors abstration" could be used but then will be needed merge over the original in color mode to get a equivalent, Mescalito color speed up that process)
Note that the result is too rough but give the basic color combination
"Back to Magic" Making of" by PhotoComiX, on Flickr
then on this last layer i used Artistic /Ellipsism trying to get the most delicate result possible and using the "ellipsis" al without outline...let say as brushes to spread the color and soften color transition that more or less give this
I found the result lovely but that was not yet exactly what needed, too much flow
To improve
1)...this may sound strange but is a good trick just add a generous amount of gaussian blur
2) After the blur recover the details and correct colors :
Copy BG layer place on top in Value mode to preserve the colors but regain outlines and grayscale
Last Duplicate alsothe Flou_Ellipses layers and move the dup on top over in grain merge mode ( or multiply ) but with not too much opacity
And finally i get 1
Copy the visible run Circlism,
That takes ages also because i run it not only on the visible but also on the other layers
(NOTE WELL Circlism layers are all ON TRANSPARENT BG that is essential!..of course here i can't show the transparency so o i added a solid BG )
on Circlism i used graphic novel to give a bit of depth and volume to the circles
(note here i use graphic boost because i want all process done within gmic...but also Layer FX /drop shadow
works well)
Note the effect of Graphic novel on the "Circles" here please ignore the black BG (i can't remove that now ,but is is the same layer as before except that the dots have a less homogeneous color
ALMOST DONE !
Copy in this order from down to up
BG
1-Colors (that with the better colors)
the Circlisms layers
Make the Circlism layers invisible, add a layer mask to "Colors" to erase the eyes (so are that from the BG to be seen)
Toggle on visibility of your favorite Circlism layer, create another layer mask, again to reveal the eyes and with a much lower opacity soft brush the nose and the lips
(If you wish repeat with another circlism layer)
PS i zipped the xcf but are too big for attachment (23 MG )
But in the layer names the xcf has embedded the setting of the gmic filters used
PostPosted: Wed Nov 23, 2011 5:40 am  (#19)
PS i forgot the xcf link
http://www.mediafire.com/?x3fnjq67xdl034i
PostPosted: Wed Nov 23, 2011 5:43 am  (#20)
Very nice PC, and a lot of work.
