It is currently Thu Nov 19, 2026 8:14 pm
 Post subject: Magenta
PostPosted: Fri Dec 02, 2011 3:30 am  (#1)
ref: http://eirian-stock.deviantart.com/gall ... 4#/d4g125q
Tools used in GIMP: G'MIC Paint, G'MIC Bilateral Filter and lots of various layer blends
Tools outside of GIMP: Buzz, and Paint Engine w/ @Wetter2 preset
Not a completely GIMP render; I usually show my wackyness, but I thought would show some more conventional art that I also usually post elsewhere for this one. I nearly always use GIMP and G'MIC for all my edits. As for how I did this one, I have to keep my secrets sometime (i.e., way too many steps for a lazy guy like me to outline; lol). Hope you all like the result. :)
Uploaded with ImageShack.us
 Post subject: Re: Magenta
PostPosted: Fri Dec 02, 2011 3:40 am  (#2)
:bigthup I like it.
PostPosted: Fri Dec 02, 2011 3:45 am  (#3)
Thanks Mahvin. The secret with the watercolor bleeding is Paint Engine w/ @Wetter2 preset. Works fine in Irfanview (which I use as a surrogate via copy/paste since it's faster doing so then Shellout. Don't believe Paint Engine works in XNView but am not sure. I know Impressionist doesn't work in XNView, but it does work fantastic via PSPI (one of the few PS filters that wasn't broken; still have to use RobA's trick to get it to work in GIMP though). Both Impressionist and Paint Engine are 2 of my favorite artistic filters that I use from time to time. :)
PostPosted: Fri Dec 02, 2011 5:08 am  (#4)
Very nice Lyle. I love the way you combined that orangy red hair in with Magenta. It is very striking.
PostPosted: Fri Dec 02, 2011 6:11 am  (#5)
Lyle i was able to get Paint Engine to work by placing the 8bf and ini file in the same folder and linking PSPI to it.
Restart Gimp you get the not found in image resource error (like Impressionist). Close Gimp.
Open the pspirc file in Notepad ++ search for pe -
Then add this just as with Impressionist after the ps plugin path line ---.
    <entrypoint menu-path="<Image>/Filters/Paint Engine/Paint Engine..." image-types="GRAY* RGB* " entrypoint="ENTRYPOINT1"/>
before the </ps-plug-in> end tag.
Now restart Gimp :)
PostPosted: Fri Dec 02, 2011 8:02 am  (#6)
OK. Thanks Rod! (a guide to how to run some *.8bf)
Paint Engine Works.
Now he can explain "Buzz"?
PostPosted: Fri Dec 02, 2011 8:28 am  (#7)
Excellent; thanks Rod. Thought I had tried this before like with Impressionist, but I guess not since it did work. :)
PostPosted: Fri Dec 02, 2011 8:37 am  (#8)
Paint Engine Works.
Check Trimoon's site out for details MareroQ. Buzz 3 is abandonware (i.e., can't buy it), but Trimoon hosts it (so free). :)
http://asnailpace.com/blog/buzz-pro-v30/
PostPosted: Fri Dec 02, 2011 9:35 am  (#9)
Thanks Lyle!
I have a Buzz § Paint Engine.
What's next?
PostPosted: Fri Dec 02, 2011 10:28 am  (#10)
Go to Trimoon's site again and click on Impressionist. It's a granddaddy (originally created by Microsoft and shipped with Office 2000 as I recall), but still an extremely powerful plugin to this day. Works in GIMP too (via PSPI) if you use RobA's modifications similar to what Rod showed for Paint Engine. It doesn't work with transparancies though (ie, no alpha channel if you run the filter). :)
PostPosted: Fri Dec 02, 2011 10:36 am  (#11)
I love your last ,beautiful image
PostPosted: Fri Dec 02, 2011 11:05 am  (#12)
Thanks PC. :)
PostPosted: Fri May 18, 2012 2:07 pm  (#13)
Hi Lyle.
I have a question - is the buzz Pro.8bf works for you in Gimp 2.8?
For me it starts, it runs in the preview - but does not give effect to the picture ...
PostPosted: Fri May 18, 2012 2:26 pm  (#14)
I use Irfanview as a surrogate for buz (via copy/paste since it's faster then launching Shellout; lol). I didn't thing Buzz would work in GIMP (could be wrong, but thought I tried this even knowing the tricks for Paint Engine and Impressionist but this plugin won't work in GIMP). The face that you are gettinga a preview in GIMP is promising though. The process should start as soon as you click OK. If nothing happens, then it appears that it won't work in GIMP. :)
PostPosted: Fri May 18, 2012 3:11 pm  (#15)
Thank You for the tip - it works in IrfanView (in XnView no).
I like the plugin with the option: save parameters...
PostPosted: Fri May 18, 2012 4:08 pm  (#16)
Impressionist don't work in XNView either but does in Irfanview. Not sure what the issue is. :)
PostPosted: Fri May 18, 2012 5:32 pm  (#17)
That's a beautiful image and the colours are gorgeous. I love her flaming red hair.
PostPosted: Sat May 19, 2012 7:49 am  (#18)
:coolthup
