It is currently Thu Nov 19, 2026 6:20 am
 Post subject: From Colors to BW, to lineart, and back
PostPosted: Thu Jul 08, 2010 9:49 pm  (#1)
the starting point was a set images all colors of the rainbow derived full spectrum circle
viewtopic.php?f=11&t=296
But since so many appreciate for the colors i was tempted to convert in BW...because if you remove all the nice colors from a good shape, what reamain is glass, or silver
CLICK on the IMAGE to ENLARGE (and see the details )
The very large size and the whole serie are here
http://www.flickriver.com/photos/photocomix_mandala/
SHOCKING PINK
NO COLOR
A TOUCH OF HUE
HEAVY COLOR WHEELS
SOFT BW
CELESTE....
BLOCKY WITH SOFT HUE
BLOCKY GO BACK TO SHoCKING & CATCHY COLORS
LINEART
LINEART & COLORS
BACK TO BW
 Post subject: Re: From Colors to BW, to lineart, and back
PostPosted: Thu Jul 08, 2010 9:55 pm  (#2)
my fav is lineart with colors.
PostPosted: Fri Jul 09, 2010 4:36 am  (#3)
Those are SO neat, I haven't been able to get the procedure right yet. I've been doing ok with a kaleidoscope and fractals but yours are way cooler.
PostPosted: Fri Jul 09, 2010 11:30 am  (#4)
:clap
PostPosted: Fri Jul 09, 2010 2:48 pm  (#5)
Those are sooo awesome! =)
I love the Celeste one.
PostPosted: Sat Jul 10, 2010 6:07 am  (#6)
thanks for the comment, i hope to found how to merge them (but are much more ) in a animation
The problem for animation is that i could figure out a way to simultaneusly pan and zoom, and then crop
PostPosted: Sat Jul 10, 2010 6:23 am  (#7)
there are tons of Kaeidosope script and plugin but none work as i wish ,except a free PS plugin: Kaleidoscope from Medhi
And i have to use with a image viewer (xnview but also irfanview or other will work ) and copy and paste in gimp the result
The plugin will work in gimp with pspi but the preview would be not correct and a good preview is essential for similar edits
I don't know solution for Linux or Mac, there is a Mathmap code, quite promising but not sufficently polished,
Gmic too have a kaleidoscope filter but it does a lot of weird things, some apparently very weird, but not what i hope
It is not easy define what "wrong" for me in all the Kaleidoscope plugins
basically the different sectors don't merge smoothly and the offset, when is included in the option do not work well
(with offsetting there is a problem...what to do if the needed pixel is outside of pixel boundary
there are 3 possible solutions,
1 use BG color to exclude ,
the other 2 are warp, that is the most used but work well only if the images are symmetrical in both direction
and mirror, that give better result but for some weird reason is less used )
