It is currently Thu Nov 19, 2026 3:00 pm
 Post subject: New style---Digital Graffiti
PostPosted: Sun Dec 04, 2011 4:38 pm  (#1)
Not the graffiti on the walls but that with colored pastels:
i had a flash in my school (what is before high school? that one) was a amazing teacher and she teach how to make graffiti with pastel:
you draw something with colored pastel, doesn't need to be accurate but should caught be the basic shapes
Then you grab a black pastel and you cover everything with a thick layer of black pastel
Last you grab a blade and you carefully peel off the black following the image contours
Maybe i found how to emulate digitally the process, it is even simple (but the result are still a bit rough..and you should find a adapt image...
airplane1 by PhotoComiX, on Flickr
graffiti-airplane by PhotoComiX, on Flickr
ORIGINAL
Group 1 boarding the plane by mckaysavage, on Flickr
Our ride home by mckaysavage, on Flickr
 Post subject: Re: New style---Digital Graffiti
PostPosted: Sun Dec 04, 2011 4:44 pm  (#2)
Almost looks like chalk PC. :)
PostPosted: Sun Dec 04, 2011 5:01 pm  (#3)
I like it though!
PostPosted: Sun Dec 04, 2011 5:27 pm  (#4)
too lazy to write a official tut with screengrab etc...but is very simple and you may look the xcf
1 )dup the layer Gmic/Artistic/hard sketch, check negative
play with the setting to have some really white lines
(or use after curve or level to adjust...you don't want all the lines of pure white because pure white will not get the color
but you want some pure white lines and the rest of a quite light grey..the rest must be solid black)
2 ) move the original on top in COLOR mode
if you do in the first image you will get this
3 ) is optional to add highlight :
Dup again the original run Charcoal filter, place the layer on the very top in Soft Light mode
But maybe i like more without charcoal
airplane1.zip [1.94 MiB]
Downloaded 137 times
PostPosted: Mon Dec 05, 2011 1:41 pm  (#5)
I was hoping that at the end of the post will be a link
for GMIC (as for: I should do something to promote my pattern: http://www.gimpchat.com/viewtopic.php?f=11&t=3184&start=0)
I do not believe in the excuse of laziness ...
PostPosted: Mon Dec 05, 2011 2:50 pm  (#6)
UUUHHH IFORGOT TO UPLOAD THE PATTERN!! :gaah
Too bad i delay because i hate fill deviantart submission form it took ages and can't be done as a batch..but ok i will do tonight
I do not understand well your comment about lazyness and gmic
I am not that lazy, i have no problem to give the link for gmic...here copy this
gmic sourceforge
and paste in the search box of your browser, and press enter...the first results are the right one
As you see i am not that lazy i explaned perfectly how found the link to download gmic...or somebody need me expanding the point ?
PostPosted: Mon Dec 05, 2011 3:18 pm  (#7)
Inspiration is always on your side.
Link gmic sourceforge not works.
Only the news, you provide, are inspiring ...
Your work is always a new inspiration - do not disappoint me ..
PostPosted: Mon Dec 05, 2011 3:39 pm  (#8)
A quick color inversion and desaturate makes it look like a sketch.
PostPosted: Mon Dec 05, 2011 5:43 pm  (#9)
You traced the origin , you did the way back:
i used a sketch filter set to negative, and then i placed back on the original
But ..What if a "sketch" or anyway bw duplicate is used not as a layer but as a layermask?
let say as BG a sharpened dup
above a smoothed dup and the "sketch" layermask...
huummm...i should try :paint
PostPosted: Mon Dec 05, 2011 6:02 pm  (#10)
And then apply some sort of texture to the layer? You could get a pretty cool sketch effect.
PostPosted: Mon Dec 05, 2011 7:46 pm  (#11)
Huum...about textures gmic allow to load images from the net.
This was never used for filters but allow to load and appy any texture
But i don't want astray first i want make a filter from this process a filter that
apply a sketch filter on a dup + negative
blur the original
the sketch layer go on top in" lightness" mode
Ok if not tonight, tomorrow will be ready
IThere are other filter around that may emulate Pastel Graffiti?
PostPosted: Mon Dec 05, 2011 10:59 pm  (#12)
you two are dangerous together!!!
PostPosted: Wed Dec 07, 2011 12:29 am  (#13)
graffit.on.black by PhotoComiX, on Flickr
from
Street Painter by pedrosimoes7, on Flickr
PostPosted: Wed Dec 07, 2011 11:11 am  (#14)
[align=center]But the hardest test for a similar filter is portrait..i believe it pass the test
Graffiti on Black : japanes flute by PhotoComiX, on Flickr
From
the musical geisha by Jesslee Cuizon, on Flickr
Sure it is a bit peculiar as technique but has a strong visual impact
[/align]
PostPosted: Thu Dec 08, 2011 10:01 am  (#15)
I was hoping a bit more of C&C on this technique because i have a sort of mixed feeling i am not sure if i really like it
well i like for the strong effect and because it is very close to the original media but has the original technique the effect is rough , but also quite effective
anyway at the end i wrote as gmic filter , testing now for hidden errors (so don't rush to upload filter now...wait at least 1 hour )
here on bird
PS that sort of dotted pattern in the bird BG is only on the screen of my PC or you may see it ?
PostPosted: Thu Dec 08, 2011 11:53 am  (#16)
Maybe, for those interested, the address of the code?
PostPosted: Thu Dec 08, 2011 12:04 pm  (#17)
ok i put on my source now.
PostPosted: Thu Dec 08, 2011 12:15 pm  (#18)
ok you should be find a new filter in Artistic "Black Crayon Graffiti"
PostPosted: Thu Dec 08, 2011 4:37 pm  (#19)
PhotoComix wrote:
here on bird
I see the dots...quite interesting technique
PostPosted: Thu Dec 08, 2011 5:44 pm  (#20)
i do not like much that dots .. i made the filter that now should make the black withouts that dot pattern
the filter is in gmic/artistic/ black crayon graffiti
i
