It is currently Thu Nov 19, 2026 3:01 pm
 Post subject: Dice Mosaic
PostPosted: Tue Dec 13, 2011 12:58 pm  (#1)
Please click this thread for details. Originally, I was using ASCIIgen to create them, but now I'm happy to say David created a cool preset for G'MIC which I used for this result. :)
 Post subject: Re: Dice Mosaic
PostPosted: Tue Dec 13, 2011 1:20 pm  (#2)
Lyle, that is so cool.
I tried one of a single apple using white dice. BTW, folks, the filter is in G'MIC > Patterns > Dices
PostPosted: Tue Dec 13, 2011 1:57 pm  (#3)
I like the font, Lyle. Your example is very cool.
PostPosted: Tue Dec 13, 2011 2:10 pm  (#4)
You gave me an idea, Odin.
Used the text tool, then put a background behind the text and used the filter on it. Tried black and white dice.
PostPosted: Tue Dec 13, 2011 2:32 pm  (#5)
Just wondering, but maybe having the dices outline in transparent (instead of gray as it is done now) would be nicer.
EDIT : Done, outline is now in transparent color.
PostPosted: Tue Dec 13, 2011 2:39 pm  (#6)
I think I kind of like those lines. I used the color selector to select them, then deleted. I couldn't get the places where they intersected without messing up the black dots.
PostPosted: Tue Dec 13, 2011 2:42 pm  (#7)
Now, this should be more flexible with the transparent color (see my post edit above :) ).
PostPosted: Tue Dec 13, 2011 2:52 pm  (#8)
You were way, way ahead of me David. Tried with new transparency, put a red bg behind it and did a screen shot. Actually, it's nice to have a choice.
PostPosted: Tue Dec 13, 2011 4:55 pm  (#9)
Cool David; was going to ask that transparent feature but had to take Dad a few places and just got back. :)
PostPosted: Tue Dec 13, 2011 11:38 pm  (#10)
A very easily implemented variation (resize original to the same dimension of the resulting dice render), then run pixelize to the same dimension as the dice size chosen, then run B/W Stamp and set the resulting layer to difference. :)
PostPosted: Wed Dec 14, 2011 9:23 am  (#11)
OK; another wacky variation this time taking lessons from the truchet experiment a few weeks ago (using layer masks). :)
