It is currently Thu Nov 19, 2026 6:31 pm
 Post subject: Cobblestone Mosaic.
PostPosted: Wed Jan 11, 2012 1:39 am  (#1)
Voronoi Stipple, then both distorted and textured using Inkscape. All the blending done in GIMP of course. Maybe a stretch to say that this is GIMP art, but at least it stayed, for the most part, open source. lol
ref: http://www.fontplay.com/freephotos/seve ... 806-03.jpg
 Post subject: Re: Cobblestone Mosaic.
PostPosted: Wed Jan 11, 2012 2:02 am  (#2)
Excellent, Lyle!
PostPosted: Wed Jan 11, 2012 2:40 am  (#3)
Thanks Odinbc. :)
PostPosted: Wed Jan 11, 2012 7:25 pm  (#4)
Just continuing on with this binge and no need to start another thread. :)
ref: http://www.fontplay.com/freephotos/imag ... o-1708.jpg
Uploaded with ImageShack.us
PostPosted: Thu Jan 12, 2012 1:10 pm  (#5)
I've been away a while, so this is the first I've seen these. These are amazing!! I formally request a tut. (it can't hurt to ask)
My Sigs = My Photos
PostPosted: Thu Jan 12, 2012 2:05 pm  (#6)
You know me and tuts PM; I will give you my flow though. I first run the Voronoi Stipple program on the target. The target itself is key though. You have to pretty much flatten the light. I just use G'MIC's Gradient Norm preset increasing both the Smoothness (soften the edges) and Min Threshold (darkens but also, more importantly, cleans the noise some). I then dup the result and set the Top to Grain Extract and decrease Opacity to 50%. No, I feed this result into Voronoi Stipple. I open the resulting SVG file in Inkscape and run a variety of presets. First, I run Cracked Glass (distorts the circle into something that looks more like cobblestones; sometimes I do this step multiple times). I then texture it some by running the bark preset. I then add some gloss by running Jam Spread preset. I then port the result in GIMP and colorize the stones (many ways to do this; I create a white cutout of the stones and then use G'MIC's Shape Average and that result I blend in with the stones (using various layer properties such as color, overly burn, etc; sometimes all the above. Do this step at the seat of my pants.). Forgot to add that I do squeeze the stones closer together using G'MIC's morphological filter (dup the stones and run it on the lower layer; still some more nuances then that though). :)
PostPosted: Thu Jan 12, 2012 2:13 pm  (#7)
A very condensed guide.
Master PhotoMaster can cope.
Something for beginners?
PostPosted: Thu Jan 19, 2012 3:02 am  (#8)
Awesome :)
PostPosted: Thu Jan 19, 2012 7:57 am  (#9)
Great results Lyle.I haven't used Voronoi Stipple in quite some time.I wonder what kind of results you could achieve using Ghost with these steps. :)
PostPosted: Thu Jan 19, 2012 10:09 am  (#10)
Thanks Deb; What is Ghost Rod; did you mean Ghostscript? :)
