It is currently Thu Nov 19, 2026 6:30 pm
 Post subject: Just playing around today
PostPosted: Fri Jan 20, 2012 1:30 pm  (#1)
Nuttin' much. Just practicing with my toys.
 Post subject: Re: Just playing around today
PostPosted: Fri Jan 20, 2012 2:14 pm  (#2)
Looks nice Drac. Assuming you used Mathmap (let me know if not); I do hope someone compiles Mathmap for the 64-bit version of GIMP soon. :)
PostPosted: Fri Jan 20, 2012 3:08 pm  (#3)
Ohhh I love the reflection...very nice indeed. Mathmap? *goes to do some looking ups*
“There´s tools and colours for all of us,
to lend from nature to make the world
more understandable and beautiful”.
PostPosted: Fri Jan 20, 2012 3:56 pm  (#4)
Nope! Map to Sphere. I never could get that pesky Mathmap to work. It shows up, but I can never get an image in the window and all I get in the dialog are little squares instead of words, etc. This works for my purposes.
PostPosted: Fri Jan 20, 2012 4:07 pm  (#5)
the MM version i included in gimpvideo should work well
If any problem just change the option for language...it is about the number format but the option to change is in language options
You want ,as example 1 million and 50 cent written as 1,000,000.50 NOT AS 1.000.000,50, please note dots and commas that is needed from MM to works well
ok sorry for the ot on mathmap...nice golden globe come out well
PostPosted: Fri Jan 20, 2012 4:33 pm  (#6)
Very cool looking sphere Draconian! :)
PostPosted: Fri Jan 20, 2012 4:45 pm  (#7)
Thank you, thank you. (bows at the waist)
PC - I'm not sure I understand exactly what you mean. Where exactly do you change the option for language? Is that during install or can I go back and fix it after it is installed?
I never heard of Gimpvideo. Whassat?
PostPosted: Fri Jan 20, 2012 4:52 pm  (#8)
I think PC means the language on your machine.It should see the numbers with commas and not dots.
PostPosted: Fri Jan 20, 2012 6:19 pm  (#9)
Still don't know where to go to effect any changes.
PostPosted: Fri Jan 20, 2012 9:16 pm  (#10)
Ooooh, shiny, I love shiny. This would make a great tutorial. shiny.
