It is currently Thu Nov 19, 2026 5:44 am
 Post subject: Happy Hippy Quick Sketch (and other Gmic styles...)
PostPosted: Tue Jul 27, 2010 8:37 am  (#1)
Old happy hippies may found difficult mantain the concentration for more then few minuts but they may develop skills to quickly focus and grab the very essential ...
Result may be something as
Old Happy Hippy Quick Sketch:
Old Hippy Slower Sketch
But, in more meditative mood they may add new details
more and more details... But there is the risk of overdo
Old Hippy Overdone Sketch
Collateral Effects
As always there are collateral effects...some interesting
Heavy Mood Dark Sketch
The bottle of beers all empty, friends are gone..time to try the Heavy Mood Dark Sketch
The ORIGINAL is from http://www.flickr.com/photos/jabbarman/
http://www.flickr.com/photos/jabbarman/4237332103/
 Post subject: Re: Happy Hippy Quick Sketch (and other Gmic styles...)
PostPosted: Tue Jul 27, 2010 10:17 am  (#2)
G'MIC has so many choices that it's hard to choose one. PhotoComix, your images are such fun.
I tried two and will go back and try more. I love the way the images look like paintings.
Got the original image here: http://www.craftmontana.com/coddington/tt/france/ParisStreetScene.jpg
Paris
Image source.http://www.100besteverything.com/best-cities/i-2-1371_venice-wp1.jpg
Venice
And another. It's hard to do just one. :hehe http://www.dragonseye.com/gallery/d/9924-4/CartagenaIMG_0118.jpg
Cartagena
PostPosted: Tue Jul 27, 2010 11:23 am  (#3)
I used FX-Foundry for this.it is a Pastel Sketch! :paint2
PostPosted: Tue Jul 27, 2010 11:27 am  (#4)
Alek, that's very nice. :-D
PostPosted: Tue Jul 27, 2010 12:39 pm  (#5)
@O
i like mostly the first very delicate and the second on Venice that come out very well
@Alek
that cool there are many script with good painting drawing and cartoon effect
They can give very good results the problem for me is that script can't offer a preview
here there are some cool one
http://users.telenet.be/ev1/gimpphotoeffects_en.html
PostPosted: Tue Jul 27, 2010 1:46 pm  (#6)
I re-did Cartagena.
B&W Sketch
B&W Pencil
Thin Brush smoothing
PostPosted: Tue Jul 27, 2010 2:58 pm  (#7)
:clap I like the last Cartagena
Tom Keil wrote a tut on make realistic sketch with gimp/gmic
http://www.mediafire.com/file/7zcil4tndkhr17k/How
he used masks and a PS plugin for speed up the creation of mask (luminosity mask to use as layermasks )
I never used masks till now ....(as you i use often instead a ovelayered BW-pencil )but i think is a very good idea.
PS no plugin is strictly needed to create luminosity mask,...quoting Tom
"It is not really difficult to create the luminosity masks without Simpelfilter. Quick and dirty: Use threshold to define your shadows and your highlights, blur the mask images, for shadow mask invert, and paste them in as layer masks. Disadvantage: no transitional tonal range, but in many cases this will be good enough.
More accurate way: Desature the image copies which will give your masks. Apply levels on both, move the blacks up to define your shadows and the whites down to define where the transitional range ends. Adjust Gamma and afterwards adjust contrast to define smoothness of the transitional range. For the shadow image invert and paste them both in as layer masks.
I just recommended Simpelfilter because it is quicker and more intuitive to use. "
I use italic for what is for me the best solution ..treeshold is too simplicistic and dirty
PostPosted: Tue Jul 27, 2010 3:09 pm  (#8)
Unfortunately those plugins won't work in Linux: PSPI & Simple filter. :( I'll have to give your method a try instead of simple filter.
I agree with you about threshold. It's baaaaaaaad. :hehe
PostPosted: Tue Jul 27, 2010 3:16 pm  (#9)
I believe i have that SimpleFilter around here somewhere, ill have to look. =)
Every time i dl a new FREE filter i upload the original ZIP or RAR to my Media-Fire account so i have quite a collection there. =P (about 2700 plugins last i looked!). This would include 8bf's also.
One of these days i will have to ask for permission to write out the link to the folder to make just about every plugin available for GIMP accessible. heheh ... Then anyone could just browse through the folder and dl whatever one they want.Sort of like a PS and GIMP plugin repository. =P
PostPosted: Tue Jul 27, 2010 3:23 pm  (#10)
PSPI more or less work also in Linux...there is a version for linux too (just the same exe + another file ) just require WINE installed.
but in linux works ...so and so, filters are exectuted correctly but the preview and even the interface of the plugin may be messed up.
the level method should work well
PostPosted: Tue Jul 27, 2010 3:33 pm  (#11)
PostPosted: Tue Jul 27, 2010 5:50 pm  (#12)
Nice one !
The tortoise shell has a color (the light buish ) identical to that of the bg, i believe that darkening a bit that color only inside the tortoise shell will make pop it out more
PostPosted: Tue Jul 27, 2010 6:13 pm  (#13)
Think this works better? I used Brightness and Contrast first, then Hue & Saturation on it.
PostPosted: Tue Jul 27, 2010 6:18 pm  (#14)
Very cute turtle "O"
PostPosted: Tue Jul 27, 2010 6:19 pm  (#15)
Thanks Molly. G'MIC is wonderful.
PostPosted: Tue Jul 27, 2010 7:42 pm  (#16)
yes now pops out
PostPosted: Tue Jul 27, 2010 8:18 pm  (#17)
O, I am waiting to see if you use G'mic on some new 'O's, although the current one is so pretty I would hate to see it go.
PostPosted: Tue Jul 27, 2010 8:34 pm  (#18)
It's stored on the ftp site so I can get it back easily. Never thot of using the plug-in on my sig. Bet the one I have up now would come out nice. Gonna try it.
You gave me an idea. Image
PostPosted: Tue Jul 27, 2010 9:55 pm  (#19)
i messed up with masks so the result is totally different from what planned
Doesn't look too bad of my monitor but on a more contrasted or dark monitor i fear will seem a dark blob
PostPosted: Tue Jul 27, 2010 10:03 pm  (#20)
I like that, PhotoComix. It kind of makes me think of St. Elmo's fire or some kind of electrical phenomena.
