It is currently Thu Nov 19, 2026 6:30 pm
 Post subject: di Blasi's Artificial Mosaic Create and more then a few G'MIC tricks.
PostPosted: Sat Jan 28, 2012 12:19 am  (#1)
Just having some fun now. :)
ref: http://www.gz4.it/gdiblasi/pubblicazioni/mosaic.php (scroll all the way down to the java routines; he makes the jar file available too so you can save and run locally which I do).
 Post subject: Re: di Blasi's Artificial Mosaic Create and more then a few G'MIC tric
PostPosted: Sat Jan 28, 2012 1:21 am  (#2)
Love the way you added the people Lyle. :)
Are those the same crop circle peeps you use? :lol
PostPosted: Sat Jan 28, 2012 1:48 am  (#3)
Here is mine
PostPosted: Sat Jan 28, 2012 1:54 am  (#4)
Same image where I got the other guys, but these are different (bigger; even so, I had to uprez them to make the size relation almost believable; lol). di Blazi's mosaic programs are quite addictive but he places size constrants. Just wish I knew how to java and edit jar files. I would take the contraints out. I know he uses a special GIMP language for java (jGimp) in order to create his Jar files but I'm not really that familiar with it. :)
PostPosted: Sat Jan 28, 2012 2:03 am  (#5)
By the way, in order to get the consistent raised result, I used a solid white as the source image and depended heavily on an external path file for the bricks to follow the path. I used G'MIC's Shape Average to colorize the bricks. :)
PostPosted: Sat Jan 28, 2012 9:49 am  (#6)
Some more experiments. This time I used Rob's Mosaic Helper to create the edge mask and also used G'MIC's morpholgy preset to clean them up some. :)
PostPosted: Sat Jan 28, 2012 12:14 pm  (#7)
i like both !
PostPosted: Sat Jan 28, 2012 4:25 pm  (#8)
Pretty good effect Lyle.
PostPosted: Sat Jan 28, 2012 5:30 pm  (#9)
Thanks for the comments. Just got back (bought a new mouse; sad that my last lazer lasted little over a year; the button went wack and finally got tired of fiddling with it; new mouse supposedly has a battery life of over a year; we shall see) and still trying to get comfortable with my new mouse. :)
