It is currently Thu Nov 19, 2026 4:26 pm
 Post subject: The Nest of the Living Cages
PostPosted: Mon Feb 06, 2012 11:21 am  (#1)
this was a long trip started when saw this on deviantart
from allthenightlong http://photocomix2.deviantart.com/favourites/?offset=24#/d4nwtcr and when i noticed that the author was so nice to share the parameter
PHASE 1
So it starts the challenge;
i want transform the cold metallic place in something organic ,rich of life as a tropical place ,..hopefully in :
the Nest of the Globular Bamboo Cages.
and after a few attempts...
The Net of the Rolling Cages by PhotoComiX, on Flickr
(PS did you see the BG ? that is not postwork is a raw fractal ,MB3D allow to include a image as BG..)
Got it now time to find a good camera positions and the best lens
a overview (this was quickly edited with gimp: i duplicate the layer converted the dup in BW using gegl c2g, and used that to boost the details visibility and color contrast
The Nest of the Rolling Cages by PhotoComiX, on Flickr
Not edited
A BW study
BW FRACTAL :The Net of the Rolling Cages by PhotoComiX, on Flickr
Ooopss the horizon line is really oblique here
...oh well ..Obviously because that shows the Hill of the Globular Bamboo Cages !
..soon i will bring you back to the Valley (at soon i fix the horizon line :mrgreen: )
The soft green living cages of Álfheimr by PhotoComiX, on Flickr
BTW it looks cool also in Bw
BW fractal :The Net of the Rolling Cages by PhotoComiX, on Flickr
Humm ---let's go back to the Valley and try a different camera position
Now put more lights and zoom in !
that was better but there i forgot the BG :gaah
Let's try another shot with BG included
The green soft rolling Cages of Álfheim by PhotoComiX, on Flickr
Moving around the camera
oh this should be where the Valley end and the Hill start to raise ..
OK this the end of Phase 1,Don't miss Phase 2 and the Attack of the Bamboo Spider !!
 Post subject: Re: The Nest of the Living Cages
PostPosted: Mon Feb 06, 2012 11:37 am  (#2)
Those are very cool PC. Some of them look 3D.
PostPosted: Mon Feb 06, 2012 12:14 pm  (#3)
Wow; definitely cool stuff PC. Amazing that these are generated art; have no idea how the equations work to create these though. :)
PostPosted: Mon Feb 06, 2012 12:31 pm  (#4)
Maybe because they are 3D :lol so is possible navigate inside and around
And believe or not i had success in a very risky maneuver ,
move at almost floor level a bit above the floor but below that sort of greenish roots..was very difficult because i have no idea on how cut thought obstacles (i know i may but no idea of how.)
And even more i finally tried to modify also the other parameters and...from than Phase 2 started
PHASE 2 intro
In Álfheimr there is a almost forgotten place because Elves never use prison or cages
But once in a time , in a very special occasion, they had no choice and they made a deal with the Old Creatures
No Iron or concrete no bars or sad gray wall with sharp angles for the Elfic Prison :
but soft globular cages of green living bamboo flexible and pulsing with live,always rolling always culling
Soft and green ,kind , kindly humming cages but also indestructible
from where never was a escape
Also because that is is the Dominion and hunting place of the beautiful , bizarre ,poetic but deadly Bamboo Spiders,
Their rules are so simply as effective :
1) visitors are welcome if invited, or even if respectfully ask audience before trespass the border
2) prisoner are treated with all kindness and respect but respecting the logic :
" prisoners" remain " prisoners" only if inside theirs cages
So logically if outside are no more imprisoned,... so should be considered Uninvited Guests ,as so as Gifts from the Goddess,... delicious pries to be captured and fertilized
3) It is a extension of 2:
except authorized visitors what else outside the cages are miracles,are Gifts from the Goddess , healthy food to feed the newborn .
(eggs and seeds are planted inside where will grow till maturity...till then they need to feed on living hosts ) .
From so long only 1 prisoner is left there all the other cages were now converted to Globular farming
I already show the Globular Cages (again most actually converted to Globular Farming) now is time for their Keepers...
PostPosted: Mon Feb 06, 2012 12:43 pm  (#5)
is any of this created with gimp?
PostPosted: Mon Feb 06, 2012 1:29 pm  (#6)
PHASE 2 , Under the Net of the Bamboo Spiders
Ok... time for the Psychedelic but deadly Guardians to show up !
ZOOM IN MORE
In The net of The Bamboo Spider by PhotoComiX, on Flickr
That good now a bigger render with the Bg image...
Cool ...now a wideangle...
Here come the Bamboo Spider by PhotoComiX, on Flickr
Almost but too wide let s try again this time a bit closer
Here Come The Bamboo Spider by PhotoComiX, on Flickr
and now a last risky attempt, what will happen if trying to modify that exotic parameters...oh yeah miracle it worked see now the legs of the spider how are changed in the junctures !
HERE COME THE BAMBOO SPIDER by PhotoComiX, on Flickr
OK that was the last
...but i could not resist to try also different colors...
The attack of the Red Gold Bamboo Spider by PhotoComiX, on Flickr
In withe looks more as if made of bones
The attack of the White Spider by PhotoComiX, on Flickr
Dark and purple with reflex
The Purple Bamboo Spider by PhotoComiX, on Flickr
a bit more bluish...
The Net of the Iridescent Bamboo Spider by PhotoComiX, on Flickr
PostPosted: Mon Feb 06, 2012 8:25 pm  (#7)
created no ...edit often
a example are the first 2 the first is edit with gimp a quite standard edit that i use often with fractal :
rendered at 150 % bigger then final size , gaussian blur close to 1px (sometimes a bit less sometimes a bit more, gaussian blur accept also decimals but must be set manually in the numeric box, slider and arrows only change integers )
2)
Dup layuer on the dup Gegl c2g (raise both iteration and sample of at least 6x than default ) :use this layer to modify the grayscale (usually in value mode )
I believe the difference evident :
Edit with gimp
Raw
PS correct the images before was to hard find the differences because i goofed and posted the same image twice.. :gaah
