It is currently Thu Nov 19, 2026 6:29 pm
which version you prefer ?
the first 14%  14%  [ 1 ]
the second 29%  29%  [ 2 ]
the third 43%  43%  [ 3 ]
none, i like all 0%  0%  [ 0 ]
none ,i don't like any 14%  14%  [ 1 ]
Total votes : 7
 Post subject: Postacard from the Mordor Canyons
PostPosted: Mon Feb 27, 2012 10:03 pm  (#1)
CREDIT
First the credit i didn't use this image directly
BUT i did use its parameters that in this case is almost the same so i want thank Andrea1981G http://andrea1981g.deviantart.com/ that shared them here
http://photocomix2.deviantart.com/favourites/#/d4qkrse
created with M3D edited with GMIC (details below the images )
I must chose one but ,as often i have too variant and i like them all so please use the pool..
1)
2)
3)
I rendered twice bigger (3200x2400) then in gimp i used gmic to apply the graphic novel2 filter on a dup layer, dosed the opacity of the dup to fade a bit the effect
in one case i used also Gegl C2G to modify the greyscale (again i applied to a dup layer set in value mode over the original)
 Post subject: Re: Postacard from the Mordor Canyons
PostPosted: Tue Feb 28, 2012 5:30 am  (#2)
very nice PC! I like the very bottom one best. glad to see you are enjoying mb3d
I'm back I think
