It is currently Thu Nov 19, 2026 6:32 pm
 Post subject: This one is for my friend
PostPosted: Fri Mar 02, 2012 7:25 pm  (#1)
 Post subject: Re: This one is for my friend
PostPosted: Fri Mar 02, 2012 7:28 pm  (#2)
what are those round things? They sort of look like plastic fly heads.
PostPosted: Fri Mar 02, 2012 7:29 pm  (#3)
its a C4D
PostPosted: Tue Mar 06, 2012 9:06 pm  (#4)
how do u like this oneImage
PostPosted: Tue Mar 06, 2012 11:05 pm  (#5)
your render seems too blurry & is fighting for attention with the background. i like the colours but perhaps a 18 kb jpeg isn't the best quality. try png if the file size isn't a requirement. the line spacing on the text could be tighter.
i like this one more than the first so keep going!
PostPosted: Tue Mar 06, 2012 11:07 pm  (#6)
I find that is a problem with many siggys...the focal seems to blend in so much with the background that i'm not sure what the render/focal is.
PostPosted: Sat Mar 10, 2012 6:34 pm  (#7)
hmmm
i find that alot with my sigs
can u provide me with a tut that may help me
PostPosted: Sat Mar 10, 2012 7:34 pm  (#8)
There are too many sig tutorials out there to zero in on. It depends what you like. I think it is important though to make your render or foreground stand out so it doesn't get lost in the background, I like to use lights and darks for this, If you use a very dark render then I would use a light back ground or visa versa. Here is one I saw but just type in how to make gimp sigs using Gimp and tons of them will come up. Try using tutorials so you can learn the basics.
Gimp sig tutorial
PostPosted: Sat Mar 10, 2012 7:41 pm  (#9)
thank you so much
