It is currently Thu Nov 19, 2026 6:31 pm
 Post subject: Pollen Swarm Attack !
PostPosted: Tue Mar 06, 2012 9:03 pm  (#1)
Gimp for the bg, M3D for the fg and final composition
 Post subject: Re: Pollen Swarm Attack !
PostPosted: Tue Mar 06, 2012 9:09 pm  (#2)
Cool! :)
PostPosted: Tue Mar 06, 2012 9:29 pm  (#3)
Those are some scary pollen PC. lol
See you still are on your 3D fractal binge. Kudos for you. Haven't posted much here since I'm on an Easter Egg binge (DAP). Might post a result of some of them soon since I still do a lot of heavy processing in GIMP (so does it still count for GIMP art? lol). :)
PostPosted: Tue Mar 06, 2012 11:09 pm  (#4)
The first one looks like some strange succulent plant, but it looks fairly realistic.
PostPosted: Sat Mar 10, 2012 2:58 pm  (#5)
PostPosted: Sat Mar 10, 2012 3:54 pm  (#6)
These all remind me of the green swarm of pollen we are fighting down here Florida right now. My white truck was lime green this morning ;(
PostPosted: Sat Mar 10, 2012 9:58 pm  (#7)
very nice PC :) happy to say I should be able to join you in mb3d work soon
I'm back I think
PostPosted: Sun Mar 11, 2012 3:02 pm  (#8)
it is really easy, i was surprised to see how much easy...
just look for M3D (as example here http://the-aposhack.deviantart.com/gallery/28953017 )
till you found scenery you really like and think that the program is a door to there:
then is just simple as copy,paste and click a button:
1)copy the parameter you see in the image comment
2 )click the..."paste txt parameter bottom "
3)and then the " calcolate 3D"
Done that you may switch more lights on, change "lens" to enlarge or restrict the Field Of View , change position.
Basically to start you should be able to copy & paste, and click a button , that open the door
then come natural learn how to move inside
and little by little even how modify at a deeper level,
zoom in/out, rotate, switch lights on/off , and change FOV and colors allow already you to radically modify the scenanery you started with
And the coolest thing of M3D, is that so many like share their parameters (not to be cloned by to be tweaked and the best way to thank for this is always remember to give the credit and a link back to the original..or the nice game will end )
and that allow you a direct entry in the 3d fractal world
PostPosted: Sun Mar 11, 2012 3:40 pm  (#9)
yep I speak with most of the artists who share there parameters rather often over on da in the aposhack chatroom
I'm back I think
