It is currently Thu Nov 19, 2026 6:29 pm
 Post subject: Who framed Harley Davidson?
PostPosted: Wed Mar 14, 2012 3:46 pm  (#1)
The frame, glass, and bg texture are by me.I can not however take credit for the bottlecap image.I got that somewhere on the web ... i believe PC showed me a place to dl bottle cap images. :)
 Post subject: Re: Who framed Harley Davidson?
PostPosted: Wed Mar 14, 2012 4:14 pm  (#2)
LOL, Definitely the most realistic glass I have seen to date.
PostPosted: Wed Mar 14, 2012 8:15 pm  (#3)
Fantastic glass...can you give a quick synopsis of how you did that?
PostPosted: Wed Mar 14, 2012 9:04 pm  (#4)
Nice composition and yes the galss come out very well
PostPosted: Thu Mar 15, 2012 6:08 am  (#5)
Thanks for the kind comments.
The frame
Create>Web Page Theme>Beveled Pattern>HRule (fill with wood pattern and cut the ends at angles.
Use color>Brightness and Contrast to get a nice wood look.
Duplicate that 3 more times and arrange as frame. (merge visible layers)
The image
Just a cropped image of a Harley Davidson bottlecap from the web. (wish i remembered the author for credit due)
The glass is very, very easy.It consists of two layers.
The glass color
1) a light bluish color (add0dc) with low opacity (27.8)
The shine or glare
2) a white (triangular looking) shape over the glass layer blurred by 11 or so and the opacity set low (41.2).
Then a cork background layer, and a drop shadow under all that.
Pretty simple really.
Here is the xcf file.This contains all the colors i used. Everything else is already merged.
HarlyDavidson.xcf [2.53 MiB]
Downloaded 127 times
PostPosted: Thu Mar 15, 2012 7:45 am  (#6)
off topic: Rod, I don't know how you made your sig but it is very cool.
PostPosted: Thu Mar 15, 2012 11:34 am  (#7)
Thanks Molly. :)
I will add it to the tutorial list for this year.
PostPosted: Thu Mar 15, 2012 11:37 am  (#8)
lol. thanx :teeth
