It is currently Thu Nov 19, 2026 6:30 pm
 Post subject: My newest sig check it out
PostPosted: Thu Mar 15, 2012 7:51 pm  (#1)
i want to make it look better
tell me what i can do to make it look better
 Post subject: Re: My newest sig check it out
PostPosted: Thu Mar 15, 2012 8:25 pm  (#2)
I think you need to darken the background, that way the foreground becomes the primary focus.
PostPosted: Thu Mar 15, 2012 8:44 pm  (#3)
Yes, ZWard, I agree. There is no contrast, foreground and background is the same color value.
You could also put more light in behind the head in your foreground man to bring him forward.
Do you still have your xcf, if so add a few layers below you foreground and mess around with some of the scripts like wind, noise, etc
PostPosted: Thu Mar 15, 2012 8:48 pm  (#4)
Okay
and yes i do still have my xcf(for once.lol)
and okay
thanks
i will post my outcome here in a bit
PostPosted: Thu Mar 15, 2012 8:48 pm  (#5)
I was thinking adding darker colors fading out from the head, however I like your idea better molly!
PostPosted: Thu Mar 15, 2012 9:02 pm  (#6)
wait what do you mean by "light behind the head"
i used a stock instead of a render
how would i do that
i tried overlay but didn't really work as good
PostPosted: Thu Mar 15, 2012 9:30 pm  (#7)
update 1:
PostPosted: Fri Mar 16, 2012 5:03 am  (#8)
War Hero,
try this tute. I did it a long time ago and it gives you some ideas on how to use different scripts for effects.
Penguins-sig-tute
PostPosted: Fri Mar 16, 2012 4:20 pm  (#9)
thanks
