It is currently Thu Nov 19, 2026 6:30 pm
 Post subject: Another new sig
PostPosted: Sat Mar 17, 2012 1:27 pm  (#1)
 Post subject: Re: Another new sig
PostPosted: Sat Mar 17, 2012 1:45 pm  (#2)
for some strange reason, the back of the background didn't become transparent
PostPosted: Sat Mar 17, 2012 2:01 pm  (#3)
PostPosted: Sat Mar 17, 2012 5:04 pm  (#4)
oh yea, forgot about that
thank you
PostPosted: Sat Mar 17, 2012 8:09 pm  (#5)
I like this better than any other of yours that I have seen..but I think it would look even better if the focal was sharper.
PostPosted: Sat Mar 17, 2012 8:22 pm  (#6)
Sharper?
okay
hold on
PostPosted: Sat Mar 17, 2012 8:27 pm  (#7)
about what level should i sharpen it
PostPosted: Sat Mar 17, 2012 8:35 pm  (#8)
I have no idea...I just think it should look crisp and clear. Play around with it and see what you can do. And don't forget to save as png and untick 'save background' when it exports as png.
PostPosted: Sat Mar 17, 2012 8:37 pm  (#9)
okay
thank you
PostPosted: Sat Mar 17, 2012 8:39 pm  (#10)
better?
PostPosted: Sat Mar 17, 2012 8:42 pm  (#11)
IMO, yes. Hmmm, wonder how it would look to have some flare coming out of the gun muzzles...nothing huge, just sort of hinting that it is shooting.
PostPosted: Sat Mar 17, 2012 8:55 pm  (#12)
ok, i'll try it
PostPosted: Sat Mar 17, 2012 9:04 pm  (#13)
like this?
PostPosted: Sun Mar 18, 2012 12:43 pm  (#14)
is that wat you wanted
PostPosted: Sun Mar 18, 2012 3:41 pm  (#15)
that's the general idea...perhaps it could be toned down a little, at one end or the other, depending on the timing of the shot.
PostPosted: Sun Mar 18, 2012 4:38 pm  (#16)
ill try that
PostPosted: Sun Mar 18, 2012 5:14 pm  (#17)
i'm curious what your focal looked like originally. the sharpening helped but its still pretty poor quality.
easier to make great sigs with great raw materials.
PostPosted: Sun Mar 18, 2012 6:44 pm  (#18)
PostPosted: Sun Mar 18, 2012 7:13 pm  (#19)
looks like a thumb of a larger image, try this one
PostPosted: Sun Mar 18, 2012 7:24 pm  (#20)
i dont have the .xct anymore
