It is currently Thu Nov 19, 2026 6:29 pm
 Post subject: Fake Doyle Spiral.
PostPosted: Sat Mar 24, 2012 8:30 pm  (#1)
I knew I should be able to do this with Droste, but the solution eluded me until I saw a sunflower droste spiral then it hit me like a sledge hammer. Stroke a large circle with a target brush (in this case my ball bearing) and then run Droste playing with all kinds of other sliders (an eyeball situation unfortunately) and voila. This too, me months (ashamed to admit) since nobody ever wants to share their code at Flickr; only show their results. Still, my wacky mind never gives up (trust me; some problems that I've solved in the past literally took me years on and off; lol). I'm no coder; only a user, so my abilities are limited. :)
Click here for tut: viewtopic.php?f=10&t=3941
 Post subject: Re: Fake Doyle Spiral.
PostPosted: Sat Mar 24, 2012 9:06 pm  (#2)
This effect would make some really nice oriental type art. :)
Nicely done Lyle, and congrats!
PostPosted: Sat Mar 24, 2012 9:53 pm  (#3)
One weakness that I've yet to figure out with Droste is the center fill problem. Still, here's another one with skittles; I'll try not to make this a binge. lol
PostPosted: Sat Mar 24, 2012 10:27 pm  (#4)
That is absolutely amazing work Lyle! :)
PostPosted: Sat Mar 24, 2012 10:34 pm  (#5)
Thanks Rod; one way to help with the center hole is to start out with bigger skittles. Won't waste anymore of Tux's storage space (and want to share this one on other sites too; lol). Click on the image for a higher rez. :)
PostPosted: Sat Mar 24, 2012 10:37 pm  (#6)
Oh yes, that worked nicely. :)
PostPosted: Sun Mar 25, 2012 12:38 am  (#7)
I think I know how to keep the center hole to a minimum size. The loop target needs to be no bigger then 50% of the canvas size. Does cause the outer Wilbers to be a little blurred though. lol
Yes, I might be on a binge now. lol
PostPosted: Sun Mar 25, 2012 1:27 am  (#8)
If you adjust Peridocity to 2.X instead of 1.X, the outer blur/aliasing is much reduced. Re-did the bearings with this in mind. I also did cheat some; use LqR to squeeze the bearings a little closer together. :)
PostPosted: Sun Mar 25, 2012 6:58 am  (#9)
very nice Doyle
PostPosted: Sun Mar 25, 2012 7:08 am  (#10)
Very sweeeet Lyle. Can I make a brooch out of the one with the glass?
PostPosted: Sun Mar 25, 2012 7:28 am  (#11)
Way cool, Lyle!
PostPosted: Sun Mar 25, 2012 8:46 pm  (#12)
You can do whatever you want with it Molly. ;)
Appreciate the comments too PC/Drac. :)
