It is currently Thu Nov 19, 2026 6:30 pm
 Post subject: Getting contrast right
PostPosted: Wed Mar 28, 2012 11:23 am  (#1)
Not exactly a tutorial so I posted it here. I long ago discovered the value of working in greyscale and adding colour on overlay layers. This enables me to concentrate on getting the correct tonal values first. The image can then be flattened and treated like a normal painting. I also open a new view, reduce it to a thumbnail and pin it with Deskpins enabling me to see at a glance whether the composition and values are correct, even when zoomed in on the main window.
 Post subject: Re: Getting contrast right
PostPosted: Wed Mar 28, 2012 12:06 pm  (#2)
Pretty smart using Deskpins like that
PostPosted: Wed Mar 28, 2012 1:42 pm  (#3)
I think GIMP's ability to show multiple views of the same image is one of its neatest, and most underused, features. Another feature that often goes unnoticed is tearoff menus -- which can make customizing your "thumbnail" view much simpler (why have menus, rulers, scrollbars, and status line in preview?).
Here is a short video showing how this can work.
http://www.kerosenecow.net/videos/multiview/
PostPosted: Wed Mar 28, 2012 2:17 pm  (#4)
I knew about tear off menus but I didn't even think to remove the scroll bars etc. Thanks for that.
PostPosted: Wed Mar 28, 2012 4:58 pm  (#5)
I wish I could get rid of the title bar. The video doesn't seem to show one, even on the main window.
PostPosted: Wed Mar 28, 2012 6:32 pm  (#6)
That is a feature of the window manager I use.
PostPosted: Wed Mar 28, 2012 6:46 pm  (#7)
I see you're a Linux user. When I finally make the switch I'll go for that, in the meantime, I'll just have to put up with the title bar!
PostPosted: Thu Mar 29, 2012 8:38 pm  (#8)
I have a question.
In Gimp-2.7.6 how do you open a new view not tabbed in single window?
When it's in single window mode it seems to be impossible as it always opens as a new TABBED image.
If you take it out of single window mode it works okay.
PostPosted: Fri Mar 30, 2012 9:52 am  (#9)
I see what you mean. For some reason, I once thought that you couldn't adjust the toolbox width in single window mode and now I know you can, I would like to use it but I can't work without a thumbnail view of my painting. I hope there's a way to open a new view separately.
