It is currently Thu Nov 19, 2026 7:04 pm
 Post subject: G'MIC Seamless Deco
PostPosted: Fri Mar 30, 2012 6:35 pm  (#1)
Didn't know where to post this so I hope its OK here. Here's a filter with a lot of potential. The first image was made from a photo of me and the second from a blank sheet.
 Post subject: Re: G'MIC Seamless Deco
PostPosted: Fri Mar 30, 2012 7:06 pm  (#2)
glad you like !
PostPosted: Fri Mar 30, 2012 7:15 pm  (#3)
Just noticed it was yours PhotoComix. Thank you. Is the effect random or does the image make a difference? I created this one from a Julia set and a stained glass version of the Julia set.
PostPosted: Fri Mar 30, 2012 7:29 pm  (#4)
It is a render filter so create a new image, the controls...well do control (a combination of Plasma and Rorsharch ) but there is also a random seed
Symmetry Master is based on a similar idea
and since you just used Stained Glass, the Psychedelic Glasswork Tyler is a tweak of Stained Glass (combined with mirror array )
PostPosted: Fri Mar 30, 2012 7:36 pm  (#5)
I discovered those two filters as well. Anything Psychedelic grabs my attention!
PostPosted: Fri Mar 30, 2012 7:45 pm  (#6)
if so you may like my last journal :paint
http://photocomix2.deviantart.com/journ ... -292900854
PostPosted: Fri Mar 30, 2012 7:49 pm  (#7)
WOOOOOW!!! I've bookmarked that page! Some gorgeous images in there - nice one! :kpix
PostPosted: Fri Mar 30, 2012 8:10 pm  (#8)
Talking of the Psychedelic Glasswork Tiler...
PostPosted: Fri Mar 30, 2012 10:13 pm  (#9)
WOW!!!!!! Thats cool.
PostPosted: Sat Mar 31, 2012 3:14 am  (#10)
Thank you.
PostPosted: Sat Mar 31, 2012 3:38 am  (#11)
way cool
PostPosted: Sat Mar 31, 2012 4:41 am  (#12)
Thank you very much!
