It is currently Thu Nov 19, 2026 7:06 pm
 Post subject: Need help finishing this sig
PostPosted: Wed Apr 04, 2012 8:44 pm  (#1)
Tell me what i can do to fix it
and i know that the text is messed up, but how can i fix it and make it better.
 Post subject: Re: Need help finishing this sig
PostPosted: Wed Apr 04, 2012 8:55 pm  (#2)
Did you use a large render? Try and use the lasso tool to get the selection in closer.
PostPosted: Wed Apr 04, 2012 9:02 pm  (#3)
I don't ever use Renders anymore, I use Stocks now, and they were small. Lasso tool?
PostPosted: Wed Apr 04, 2012 9:17 pm  (#4)
Use larger stocks then? Same effect different word. Gives better ending quality
I'm back I think
PostPosted: Thu Apr 05, 2012 4:33 am  (#5)
I don't usually do text so I don't know if this is useful, but usually when I use the lasso tool, I feather the selection to about 2 - 3 pixels to antialias.
PostPosted: Thu Apr 05, 2012 1:54 pm  (#6)
to improve i'd begin with the stock which seems poor quality. did you scale up? are you sure it isn't the thumbnail?
PostPosted: Thu Apr 05, 2012 1:56 pm  (#7)
As i stated before even veteran sig creators do not use text very often.Even they have a problem getting it correct.
I wouldn't use text at all in one.
Get a nice render (very big and scale it down)
Set 1 focal point. :)
Do not use borders. Do not use text.
Abstract bg (brushes, and gradients), or use an image bg (no solid colors)
Just a few basic rules.
PostPosted: Thu Apr 05, 2012 5:47 pm  (#8)
Thank you for the help, and ico4498 no and no
